Ghillie
PC Specification: i5-4460, Radeon RX 580, Windows 10 Pro
Action! breaking system sound
Thu Jul 04, 2019 8:34 pm
When I start Action! it makes my system sound extremely loud and distorted. Is there a way to either reset the sound settings to fix this or fix the distorted system sounds?
Re: Action! breaking system sound
Fri Jul 05, 2019 6:01 am
1. Uninstall Action!
4. Remove Action! catalog.
5. Reboot your PC.
