Demaeter
PC Specification: i5 2nd gen gtx 1060 6gb Win 10
Cant record HUD shows greyed out
Tue Jul 09, 2019 12:15 am
Hello!
Ive been using Action! without much problems for years now. Almost 1000 hours of use on Steam and this is a problem ive never found out why happens.
I record a lot of Android stuff using Nox Emulator. Been using Action! without much problems for a while now but i recently upgraded to Windows 10. Today I was going to record some more stuff and I cant seem to make it work. I could record using the crop feature instead of Game but it troubles me since it used to work without problems earlier.
HUD shows up on the program (Nox emulator) shows FPS and says its OGL but it does show greyed out. Pressing the record button wont do anything.
Action! seems to work normally on other games. If Action does recognize Nox but it wont record anything staying greyed out... What could be the problem here?
Re: Cant record HUD shows greyed out
Tue Jul 09, 2019 6:10 am
This problem is more complex and it does not lay on our side only.
You can still record this emulator using Screen or Area mode.
