ascaloninc
PC Specification: i5-4570, Intel (Integrated), Win10
Horkeys
Tue Jul 16, 2019 5:21 pm
07-16-2019
Hi Mirillis,
I'm enjoying your program so far. I would enjoy more if ALL HOTKEYS are reassignable. Do you think this is possible in your next update?
Mitillis Action User.
Re: Horkeys
Wed Jul 17, 2019 5:57 am
Not sure if it is what you meant, but you can change every hotkey in hotkeys settings tab.
ascaloninc
Re: Horkeys
Fri Jul 19, 2019 2:03 pm
07-19-2019
Yes, you are right about the Setting and then Hotkeys. However, you can only turn ON and OFF the assigned key. And another the F9 key you cannot even touch it. Also, users did ask about this because they have special keyboards like the Corsair K95 with that extra 6-keys to the left. -- All we ask is if that Hotkeys can be re-assigned or re-programmed.
ascaloninc
Re: Horkeys
Fri Jul 19, 2019 2:21 pm
07-19-2019
Thank you Poitr - I got some answers.
Return to “General Topics”
