NaughtyDog
PC Specification: I7 7700K GTX1080ti Windows 10
Disabling Preview?
Wed Jul 24, 2019 9:06 am
Hey,
there is the following issue on the newest Windows 10 version 1903. The Preview is causing microstutters, even when hidden in tray. I dont know if it has something to do with dual monitor setup, but either way it could be solved by disabling or not hooking the preview. Is there any way to do so?
thanks!
Re: Disabling Preview?
Thu Jul 25, 2019 6:01 am
Do you mean preview in Action!?
Desktop 7-25-2019 7-59-05 AM-0.jpg (43.15 KiB) Viewed 5273 times
If yes then you can just turn it off.
