Concealed
PC Specification: Intel I7 - 4710MQ, GTX 970M, Windows 10
Action - Twitch.tv - Connection Error !
Sun Aug 04, 2019 8:53 pm
Hello.
Since I've updated to version 3.9.6, Action! can't log in into Twitch.tv anymore. It's been like this as soon as I updated to the latest version. Every time I go to the Live tab the error just pops up. Trying to start the stream will only start to record as a video.
I've waited hoping a new version will get released and maybe it will fix it but it's already more than a month and I still have the same issue. Tried to reinstall and install Action! again with no success.
Anythings else I could do ?
Windows 10, up to date, latest build.
Watchman
Re: Action - Twitch.tv - Connection Error !
Thu Aug 08, 2019 7:29 am
Hello.
There were some problems with Twitch logging because of Javascript problems. This has been fixed on Twitch side and should work now.
Please logout and login again in account manager and let us know if it works now.
Thank you
Concealed
Fri Aug 09, 2019 7:55 pm
Thank you for your reply, Watchman.
I've tried to log out and log in into Twitch and I can say that the result is the same as before.
The same error message with red, even though I am logged in. Changing tabs from/to Live and any tabs will give me the same Error.
Much the same.
Watchman
Wed Aug 14, 2019 6:37 pm
Do you have enabled the 2 pass verification on your Twitch account? Without it you will be only allowed to use the Custom mode (URL + Streamkey)
Concealed
Fri Aug 16, 2019 6:37 pm
Hey. I don't have enabled Two-Factor Authentication and never had it, to be honest.
Whenever I wanted to stream, I kept it simple, only using the StreamKey provided by Twitch.
Currently, I don't think there is anything else to do except to wait. Sadly, I can't use the software anymore but I'm also dealing with a very busy period IRL.
I guess I can wait until the next update and hope the Chrome based login process will fix all the issue. At least I know it is not something on my end.
Thank you for your replies, Watchman.
ratrogue
PC Specification: AUS Laptop, GeForce 960M; Windows 10
Mon Sep 16, 2019 5:02 pm
I have the same problem. Any solution in sight?
frozenbulb
PC Specification: Intel i5, Intel HD Graphics, windows 8.1
Sat Oct 05, 2019 6:03 am
All I did was login to twitch and enable the 2 factor authentication and it finally worked on the software.
