hpf123
PC Specification: AMD Phenom II X4 GTX460 8gb ram win 64bi
Slow motion after export (INVESTIGATING)
Sun Jan 29, 2012 12:23 pm
Right i bought Action! yesterday one copy for a friend of mine and one for me. He can use it fine no problems at all but when i go to export the file after exporting the file has slow motion audio and the fps seems to drop dramatically but the length is still the same.
This is getting to be rather annoying because the only way i can fix this is by recording with no sound whilst recording with windows sound recorder and overlaying it. Which is the weird thing as it is the sound corrupting the file.
Thanks in advance
Harry
hpf123
Re: Slow motion after export
Fri Feb 10, 2012 5:04 pm
Shameless bump as im starting to get annoyed that i payed for something that doesnt seem to work :(
KimboCake
PC Specification: x6 1090t, 6970, win7 x64,
Mon Feb 20, 2012 2:01 pm
Hey Harry :)
Same problem here m8,
Example:
http://www.youtube.com/watch?v=YSQJArd8C4A&hd=1
Sun Feb 26, 2012 9:32 pm
Hi, we cannot reproduce problem in ourr labs.
Can you please provide us some info that will help us to understand the problem:
- What is your video quality mode in exporting window?
- Can you please check if problem occurs with:
* microphone set to "do not record"
* allow multichannel audio recording disabled and enabled?
Is it possible to make a short recording and share it us for investigation?
We can provide ftp server for files uploading.
hpf123
Re: Slow motion after export (INVESTIGATING)
Fri Mar 09, 2012 4:08 pm
Video quality is 1920*1080 High and the slider is set to full the microphone is set to do not rcord and i have tried both. P.S I know kimbocake (Patrick) and we have established that the problem must be with our processor as we have both got an AMD Phenom II hope that can help as i love the software
Sun Mar 11, 2012 9:56 pm
Thank you for new information.
We are invesigating this and we can confirm that it is somehow connected with some AMD cpus.
Can you please check if setting video quality to "normal" works fine?
KimboCake
Wed Mar 14, 2012 7:10 am
Ghost wrote:Thank you for new information.
Tried still same problem :(
hpf123
Fri Mar 16, 2012 9:16 pm
What kimbocake said :(
hpf123
Wed Nov 14, 2012 8:01 pm
I know this is a bump from an old post but on some games i still get the slow motion stuff with the AMD FX 6100 now and its getting rather annoying.
