OmegaF
PC Specification: i7-5930K, Windows 7 SP1
After 3 years of use, suddently critial error 104 appears
Wed Aug 21, 2019 4:53 pm
I have been using Mirillis Action for about 3 years without any problem, but since last week I haven't been able to use it. Every time I try to open it, I get the "CRITICAL ERROR 104" message and Mirillis Action closes. I have checket the http://error104.mirillis.net/ web and my hosts file is clean (no extra lines and nothing like 127.0.0.1 www.mirillis.com) and the firewall isn't blocking Action (I have even disabled it just to test it) but I still can't open it.
Last video recorded was 2 weeks ago and I haven't updated anything in my computer (Windows 7 with Automatic Updates disbled).
I have also tried opening Action with my network adapter disabled and it works, so I guess something happened last week and now I can't connect to the license verification server. Is there anything I can do to solve this problem? If I ping www.mirillis.com or mirillis.com I get response.
My Action version is 2.8.1
Thank you in advance.
Re: After 3 years of use, suddently critial error 104 appears
Thu Aug 22, 2019 6:02 am
Download the zip below.
Unzip it and run the script. Then restart your PC.
DefaultSecureProtocols.zip
(348 Bytes) Downloaded 758 times
OmegaF
Thu Aug 22, 2019 4:23 pm
Piotr, thank you VERY MUCH. Mirillis Action is working again :D
