Prosco
PC Specification: i7 7700 4.20Ghz-GTX 1080TI -Win10
NVIDIA NVENC or NVIDIA NVENC HEVC?
Thu Sep 12, 2019 3:11 pm
Hello everyone, 8-)
I'm using the X-plane 11 flight simulator and I want to record my flights. I am currently testing Action! which gives me very good results: no artifacts or lags.
I'm not very good at codec and I would like to know which codec I should focus on: NVIDIA NVENC or NVIDIA NVENC HEVC?
I said that I write in mp4, 2560x1440 in 30 fps, quality: ultra, bitrate 12 Mbps, input range: 0-255 FULL.
Thank you in advance, best regards.
PS : I am a frenchie, sorry for my english (it's google translation) :oops:
Re: NVIDIA NVENC or NVIDIA NVENC HEVC?
Fri Sep 13, 2019 6:08 am
We recommend using NVIDIA NVENC since HEVC codec in not standarized and some decoders may have problem decoding your recordings.
Prosco
Fri Sep 13, 2019 6:37 am
thank you so much ;)
Foxy06
PC Specification: Windows 10, intel core i7, 64bits
Wed Sep 25, 2019 12:08 pm
Hello !
I was recently trying to record X-Plane 11 with its internal sounds, mainly ATC, using Action! (a Mirillis company software).
This was part of preparing a YouTube video.
The problem was that X-Plane 11 was systematically freezing at the starting of Action!
NB : I have a NVIDIA graphic card.
I had a fructuous exchange with Mirillis support. The result was that, in order to achieve a nice recording of X-Plane 11 (video + sound), I needed to do the following:
Right click on desktop and select "NVIDIA Control Panel".
Go to 3D Settings -> Manage 3D settings.
Under "Global Settings" tab set the following:
- Antialiasing - Transparency -> 2x (supersampling),
- Threaded optimization -> On.
AND
- X-Plane 11 in Full Screen display
AND POSSIBLY
- Start Action!, then Stop Action!, then Start Action!
Best regards
