scryedzxp
PC Specification: Windows 10
Recording playback issue after 3.10 update
Fri Sep 20, 2019 7:16 am
After I updated to 3.10, I can't seem to playback any of my recordings through Action's video player. The video becomes very laggy and just seems to stop playing after a second but I can still hear the audio. It plays just fine with Windows Media Player.
Re: Recording playback issue after 3.10 update
Tue Sep 24, 2019 9:09 am
1. Uninstall Action!
4. Remove Action! catalog.
5. Reboot your PC.
LoneStar
PC Specification: I7-9700K, eVGA GTX2080ti, Window 10 2004
Thu Sep 26, 2019 9:47 pm
Same issue after 3.10 update. Action Player will not play videos. Followed all your steps from the above post. Reinstalled Action. Action Player still will not play video. Action Player opens momentarily then closes.
It's not a problem with the videos. I can play video with Cyberlink PowerDVD16.
Windows 10.0.18362
LoneStar
Sun Sep 29, 2019 7:36 pm
Found problem. The lastest version of RivaTuner which is installed with MSI Afterburner was preventing ActionPlayer from playing videos. I've uninstalled MSI Afterburner/RivaTuner. I'm now using eVGA Precision X1. ActionPlayer now plays recorded videos. Only problem is the X1 OSD shows in ActionPlayer video play but does not show in Cyberlink PowerDVD video player. X1 OSD should only show in game play and not videos.
