baesik
PC Specification: i9-9900k, RTX 2080 S, Windows 10 1903
Video file bitrate too low
Sun Oct 06, 2019 11:03 pm
I've tried Action! in the past and loved it, but could not justify the price without the option to at least manually choose a bitrate.
After the update to choose a bitrate, I tried the trial and the max bitrate finally worked!
With the release of this new version I saw that a forced max bitrate could be made and I decided to buy the product. Unfortunately, it seems like the video files are still recording at around 30-50mbps bitrate. This bitrate is much too low for me and I would really like to use Action! because its interface and performance are great and better than most other recording softwares.
Can anyone help me with this?
Thanks,
Dee
Re: Video file bitrate too low
Mon Oct 07, 2019 7:51 am
Video bitrate may stay lower when there is no need to encode in higher bitrate. For example if you record static desktop in 1080p then video bitrate will be something about 30 Mbps. But if you record some dynamic game then video may reach 100 Mbps in bitrate.
baesik
Mon Oct 07, 2019 12:09 pm
I do understand that. I tested it in-game with lots of movement. I downgraded to the previous version and the bitrate is now back to 100mbps. Possibly an error in the latest version?
baesik
Fri Nov 08, 2019 7:29 pm
As a follow up, I've done testing using the Overwatch highlights feature and confirmed that the latest Action! version (3.10.2), for some reason, lowers or limits the bitrate to around 60 mbps MAX even when using the force bitrate feature.
Can this truly be looked into?
Tue Nov 12, 2019 9:27 am
What hardware acceleration do you use?
baesik
Tue Nov 12, 2019 2:22 pm
I'm using an RTX 2080 Super and I record in nvenc.
Users browsing this forum: No registered users and 48 guests
