Deus
PC Specification: Ryzen 3800X, GTX 1080Ti, Windows 10 1903
Action Injector disables Gsync in fullscreen for D3D9
Tue Oct 29, 2019 2:03 pm
I have some games, that runs in D3D9, and for those games, when I run them without Action, I get Gsync, when I run them with Action, I don't.
Refreshrate is set to 144Hz, and remains at 144Hz, no matter if I use ingame or external framerate limiter at 60, it stays a 144Hz, even if monitor's OSD reports Adaptive Sync on.
If I close Action, then the refreshrate goes back to 60 Hz for 60 FPS (normal Adaptive Sync behavior).
It only does this with some D3D9 games, and only when Action is active.
Every possible thing is up to date (windows, monitor, gpu drivers, action), I tried everything, Game Mode on/off, "disable fullscreen optimizations" on/off (by the way when it's on I also loose Gsync without Mirillis, maybe a clue here ?), nothing seem to be working.
I really like this software that has been a flawless experience so far, I don't want to change, please try to investigate this if you can.
Thanks a lot.
Re: Action Injector disables Gsync in fullscreen for D3D9
Wed Oct 30, 2019 7:05 am
In which games does this issue occur?
Users browsing this forum: No registered users and 46 guests
