donga
PC Specification: i7 2600k, GTX670 SLI, windows 7
Mirillis Action installed causes low GPU usage RTX!
Fri Jan 10, 2020 9:31 pm
Hi. It has come to my attention that you don't even have to be using Action for this problem to occur! If you have Mirillis Action installed, it will lower your GPU usage by about 30%. So far it may be only RTX cards, but I haven't tested it with others. Video proof a friend made this video: https://youtu.be/uvJ3wFtNBls
Re: Mirillis Action installed causes low GPU usage RTX!
Tue Jan 14, 2020 7:27 am
Hello, we are aware of this problem and the issue will be resolved with next update.
