Dishant Shahu
PC Specification: i5-4440S, Intel HD 4600, Windows 8.1 Pro
Problem Of Last Update
Mon Jan 13, 2020 12:55 pm
When I press "F9" or Stop Rec Button, the software Freezes, crashs and restarts. When it gets opened again, the recorded file couldnt be opened or is corrupted (only happened in mp4, I havent tested it in other). Please help me fix this issue.
DuckedGuy
PC Specification: CPU: Intel Core i5-6200U
Action! Keeps crashing when I stop recording
Tue Jan 14, 2020 4:54 am
Everytime I stop recording it crashes and open up again, recording in AVI files works fine, just on MP4, at least when Action! opens up again the recording is saved.
I already updated my CPU drivers, what's my problem?
Re: Problem Of Last Update
Tue Jan 14, 2020 7:40 am
What hardware acceleration do you use?
Dishant Shahu
Wed Jan 15, 2020 7:49 am
I Use "Intel Quick Sync Video".
Update : When Hardware Accleration Is Disabled, it works properply. In "AVI" it also works properly
Thu Jan 16, 2020 7:07 am
Click on, "Start Button".
Click on, "Run".
Dishant Shahu
Fri Jan 17, 2020 7:41 am
For Some Reasons, I cant attach "dxdiag.txt". Something pops up saying 'Invaid File Extension : DxDiag.txt'.
Here is the google drive link for the "dxdiag.txt".
Google Drive : https://drive.google.com/file/d/1NdRyt1 ... sp=sharing
Mon Jan 20, 2020 8:45 am
Update Action! to version 4.0.4 and see if the issue persists.
Dishant Shahu
Tue Jan 21, 2020 8:39 am
I'm using the latest release of action! But the issue isn't fixed for me....pls help!
Wed Jan 22, 2020 7:17 am
Try installing these Intel drivers: https://dl.dell.com/FOLDER03769645M/1/V ... 14_A04.EXE
Dishant Shahu
I have moved to a new laptop.
Fri Jan 31, 2020 3:21 pm
@piotr i have moved to a new laptop and Action! is performing really well there and I don't really need any help and support right now. If I need any, I will let you know. I just wanna say, thank you for help and support, i really appreciate that. Have a good day!
