Susana E.
PC Specification: Ryzen 7, Nvidia GeForce GTX 1080, Win 10
Codec fail since Action last Update, pls help
Mon Jan 13, 2020 5:38 pm
Since the last update, all the program fail, if i try to record on twitch turn black windows.. if i set in original format (video) can see but video stop each 0:22 segs and cut the video all time.
if i save on pc.. them cant see cause request codec --
i install HEVC. and now all the video has the colors full brillant linke 356 colors or same..
here you can see video - https://youtu.be/CkxWflVgP8M -
really terrible, i try to fix but imposible .. >_<
I reinstall several times codecs.. the action mirillis program.. but nothing change.
Re: Codec fail since Action last Update, pls help
Tue Jan 14, 2020 7:42 am
Prblem with Twitch will be fixed with next update. Glitches in the video is the bug on YouTube side.
