Hellmut
PC Specification: Intel I9 9980X; SLI RTX 2080 TI; Win 10
4.0.4. Washed out colors for RE 2 REmake and SLI.
Fri Jan 17, 2020 1:47 am
Well, I saw log for new verison and have to ask: Will be SLI support for HDR in upcoming versions? SLI scaling is very important for 4K recording.
And RE 2 (DX 11) is still a problem. Nothing changed.
Thank you for support!
Re: 4.0.4. Washed out colors for RE 2 REmake and SLI.
Fri Jan 17, 2020 7:24 am
SDR content has washout colors on HDR monitors. If you play RE 2 in HDR you can record it using NVIDIA NVENC HDR 10 to record HDR content. This video will have washout colors in thumbnail and when played on normal monitor, but it will look great on HDR monitors.
HDR won't work if SLI is enabled, but we do our best to improve that.
Hellmut
Fri Jan 17, 2020 9:55 am
RE 2 in HDR and my screen is HDR, but when I turned on Action! the game colors washed out. Here another video from my phone: https://drive.google.com/file/d/1N5y31C ... sp=sharing
Just look at it, please.
Mon Jan 20, 2020 8:48 am
Thank you for the video. Do you run the game in fullscreen or borderless fullscreen?
Hellmut
Mon Jan 20, 2020 12:57 pm
Fullscreen. RE 2 HDR mode works only in fullscreen.
Tue Jan 21, 2020 3:27 pm
As a workaround disable HDR in desktop. Your game still will start in HDR but the colors should be fine now.
Hellmut
Wed Jan 22, 2020 2:58 am
Yes! Thank you! Now, please support SLI for HDR :D And Action! will be beautiful.
tylerfreeman87
PC Specification: 2700x 1080ti windows 10 x64
4.0.4 HDR10 not working for Exclusive Fullscreen games and applications
Sat Jan 25, 2020 9:17 am
Interested in getting Action! for the HDR10 and high frame rate capture.
It seems that HDR10 recording with Action! seems to either wash out or over-saturate the colours dependant on game, both on-screen and appears in the files recording. If you can switch the game to Windowed/Borderless mode it seems to work (Tested with MK11 and Borderlands 3 - Have play games and apps in HDR checked in Windows 10 settings so it's enabled in Desktop). However many games like Resident Evil 2 won't accept running HDR in Windowed mode at all and games like Assassins Creed Odyssey suffer big performance hits when not in fullscreen. This seems like a bug or oversight but probably something that can be fixed, but it is preventing me from putting a purchase on the software at the moment.
Tested HDR working in Windowed Mode:
Gears 5
Borderlands 3
Mortal Kombat 11
Cannot play or record with HDR enabled with Action! running:
Any fullscreen game
Resident Evil 2 / 7
Assassins Creed Origins / Odyssey
Please advise if this specific issue can be fixed in a future release.
