RedEr
PC Specification: Windows10 Pro-IntelCorei5 8250U
Green or black screen when playing the video
Wed Feb 12, 2020 2:26 am
Hello, good morning / evenings / nights, first of all an apology for my lousy English, I only speak Spanish and I am using GoogleTraductor.
Good.
When I record games the recording gets corrupted and the whole video turns GREEN or BLACK, I tried changing the resolution, the format, the size of the video and it still can't be fixed. The strange thing is that if I change the game capture mode to screen, it is reset. I would like to know what I can do to fix this problem.
Clarification: This problem arises after recording several videos, and the only solution is to restart the computer (laptop). Please can you help me?
specs
Model: ASPIRE A315-53G
OS: Windows 10 Pro, 64 bits
Processor: Intel Core i5 8250-U
Re: Green or black screen when playing the video
Wed Feb 12, 2020 7:16 am
Which Action! version do you use?
RedEr
Wed Feb 12, 2020 11:36 pm
Hi, I am using the current version
RedEr
Sun Feb 16, 2020 2:37 pm
Help me please, i bought this product
Tue Feb 18, 2020 7:16 am
1. Uninstall Action!
4. Remove Action! catalog.
5. Reboot your PC.
