Emre1337
PC Specification: i5-7300 HQ, GTX 1050, Windows 10,
Action Mirillis Red Font Issues
Mon Feb 17, 2020 1:25 pm
Hello, i have been using Action Mirillis since a very long time and for me it is the best Recording Software, because it gives a high performance and less lag in recording. But since 1 Month i have the Problem, that when i reocrd something in a Game everthing looks normal but in some parts there are different colors or the red font is blurry.
I am doing Gameplay Videos on my YouTube Channel and here is an example: https://www.youtube.com/watch?v=WugxFzT5tpw
You can see that everything is okay, but the red font is strange. How can i fix this?
Re: Action Mirillis Red Font Issues
Tue Feb 18, 2020 7:18 am
Please provide us more information about your problem:
Details about recording settings
Does problem occurs both for AVI and MP4 recordings?
Does it occur for every game or only for a 1 title or a few?
Does problem occurs when recording to lower resolution (480p)?
Does it occurs when recording in lower fps (30p)?
Does it occur when recording Windows desktop?
Which Action! version do you use?
Emre1337
Tue Feb 18, 2020 12:10 pm
60 FPS, Original Quality, Screen
Yes
1 Title
Yes
Yes
No
4.1.2
No
Emre1337
Sat Feb 22, 2020 2:36 pm
Why no one is helping me? I am not the only one with this problem.
Tue Feb 25, 2020 7:37 am
There will be new version soon that may help you.
Emre1337
Tue Feb 25, 2020 2:35 pm
Okay, i hope so
KarliN
PC Specification: Intel(R) Core(TM) i5-2400 CPU @ 3.10 GHz
Thank you for fixing the problem.
Sat Mar 14, 2020 5:24 am
I don't know how long has it been but it appears red-ish recording problem has been solved. Thank you very much.
Emre1337
Sun Mar 22, 2020 12:43 am
I still have the same problem, which settings do you use?
Emre1337
Action Mirillis Red Font doesn't look good, when recording
Sun Apr 05, 2020 10:09 pm
Hello, after Months of waiting and waiting and update the Problem hasn't been fixed yet. When i record something on my PC the red font looks bad and blurry. When i will have a fix for this? I bought action Mirllis, because it was the best Screen Recorder for me, but atm it is just making problems.
