schemer
PC Specification: Win10 Pro 64, i7 2600K, Nvidia GTX1080
No longer records sound
Sat Mar 07, 2020 4:28 pm
Since the last update the sound recording no longer works. I turned every audio related switch every direction and still it won't record any sound when I record a video from the screen. I downloaded a Free software that does work including capturing the sound so I know it can work. Anything else I can try??
WIN10 Pro 64
Thanks,
schemer
schemer
Action 4.1.2 won't record any sound
Mon Mar 09, 2020 7:55 pm
I tried uninstalling it and deleting the Action folder in the registry and reinstalled and still won't record any sounds.
Win10 64 Pro
i7 2600k
16 GB Ram
Nvidia 1080 Video Card
Can you help?
Thanks,
Dave
Re: No longer records sound
Tue Mar 10, 2020 7:09 am
Please provide us screenshots from following tabs:
- Video Recording (showing audio options),
- Audio Settings.
Dubbreaker
PC Specification: I9-9700 GTX 980 TI
Sun Apr 05, 2020 1:07 am
I have the same kind of issue. I have my primary and secondary set to system default but it will only record mic or system sounds but not both
Mon Apr 06, 2020 7:55 am
Open microphone settings and make sure that "Record microphone into separate audio track" option is disabled.
schemer
Thu Jun 18, 2020 11:12 pm
I still have the same problem for months now. I bought another screen recorder and it works and records sound from the screen overlay (MOVAVI) but I would really like ACTION! to work. Does anybody else have this problem or have had it and fixed it? I hate to have to uninstall it and use it on another pc.
Thanks,
schemer
Fri Jun 19, 2020 6:00 am
Thanks,
schemer
1. Uninstall Action!
4. Remove Action! catalog.
5. Reboot your PC.
schemer
Mon Jun 22, 2020 3:39 pm
I followed your instructions and still it will not record any sound. Very frustrating. I downloaded the latest audio drivers from DriversCloud yesterday and still no joy. I may go back there and see if any other drivers are relevant. I use a Logitech G35 headset but have been for many years and everything else works when it comes to sound. I sent a captured video to tech support some time ago and they said there was no sound file on the video. They told me to disable all the applications with MSCONFIG and try safe mode but when I do that I cannot even open ACTION! I tried disabling any video and sound capture apps on my pc and that didn't help. I may try MSCONFIG again and just break it down into blocks of 10 apps at a time or something. I really miss my ACTION! :(
