frank062
PC Specification: Windows 10
Action Mp4 Crashes
Mon Mar 09, 2020 1:48 am
Hi
I´ve worked with action and always have recorded in mp4, But now it only lets me record in AVI. when i try to record in mp4, it stops and
the message is that Action don´t responde, so it crashes.
I really need some help.
thanks
Re: Action Mp4 Crashes
Tue Mar 10, 2020 7:11 am
please provide us your PC DxDiag report. It will help us investigate your problem.
Click on, "Start Button".
Click on, "Run".
gohan0098
PC Specification: Intel i5 6600, GTX 1060 3Gb, Win10 64bit
Thu Mar 12, 2020 8:56 pm
Hello, I'm having the same troubles. I can't record in MP4 because the program crashes after stopping the recording, so I record on AVI but I don't get any sound as noted in another topic below. I also get some video archives I can't delete, they are stuck there. Here are my settings.
I also attach my DxDiag.
Please help us >:
gohan0098
Thu Mar 12, 2020 8:59 pm
Sorry for the double posting, but I can't post the DxDiag file, it seems like I can't attach the txt file.
Fri Mar 13, 2020 6:50 am
1. Uninstall Action!
4. Remove Action! catalog.
5. Reboot your PC.
gohan0098
Fri Mar 13, 2020 10:30 pm
Still nothing, this happens after finishing an MP4 recording. After that I can't close Action, I have to close STEAM entirely to stop it and open it again to keep trying to use it.
After recording in AVI, the audio is still missing.
Tue Mar 17, 2020 7:01 am
If you change the dxdiag file extension to .zip you will be able to add it to the post.
gohan0098
Tue Mar 17, 2020 5:20 pm
There ya go.
DxDiag.txt.rar
(16.34 KiB) Downloaded 903 times
Wed Mar 18, 2020 6:50 am
It may be a problem with audio recording. Go to Settings -> Audio and disable "record sound" option.
See if that works.
