grextian
PC Specification: Windows 7 x64, Core 2 Duo, Geforce GT525
How do i add Presets in Action!?
Sun Mar 22, 2020 5:46 am
I'm trying to add a new preset in Action! in the "Area Mode", but i can't seem to be able to make it work.
I have tried everything, but with no luck. Am i missing something, or doesn't that preset thing even work at all?
From when i bought Action! (starting from Version 3.7.1), i have not been able to do this, even how many
times i have tried. I have tried every version since, and i am now using Version 4.2.0.0. When i click the "+" symbol,
nothing is stored, even though i have set and written a size manually.
How do i make it work. How can i get it to save the presets?
Thanks in advance!
Re: How do i add Presets in Action!?
Tue Mar 24, 2020 8:29 am
To add new preset follow the steps below:
- set the size of area you want to save as a preset,
- click plus button,
- type a name for a new preset,
- press enter to apply
