TinyChris
PC Specification: i9 9900k, RTX 2080ti, Windows 10 latest
Doom Eternal / Vulkan
Sun Mar 22, 2020 10:08 pm
Hello, i want to report that Doom Eternal is not recordable with Mirillis Action! It crashes the process instantly. https://imgur.com/a/1EhWGXz
Action does also crash the Process if i try to use other Recording Softwares, even though it is not opened in my processes. So maybe you could try to make it work for Doom Eternal. :)
Re: Doom Eternal / Vulkan
Tue Mar 24, 2020 8:31 am
Thank you for the information. We will investigate the issue.
Driftwood Gamersyde
PC Specification: i9 9900k / 2080 Ti / Windows 10
Tue Mar 24, 2020 8:53 pm
If I may, HDR capture does not crash the game but the FPS counter shows 120 fps, which is impossible as my TV is 60 Hz. Because of that though, even when limiting capture to 60 on Mirillis Action, it does not record the game properly and the file I get is unusable. There is definitely something wrong with Mirillis in this game. Sadly, until it is fixed, I cannot post any HDR content of the game on our website.
Wed Mar 25, 2020 9:30 am
Game can render more frames per second than the monitor's refresh rate - unless you enable VSYNC. What happens when you record in HDR? Why the recording is unusable?
Driftwood Gamersyde
Wed Mar 25, 2020 3:35 pm
I know that, but vsync makes no difference, hence the problem.
Driftwood Gamersyde
Wed Mar 25, 2020 3:39 pm
PS : the recorded footage is unusable because either the image doesn't move at all (sound is perfect though) but it seems to be shaking like crazy, or it does move but there seems to be ghostly images of the game shaking everywhere. It's hard to describe actually...
Thu Mar 26, 2020 7:46 am
Could you also report this issue to our technical support via support@mirillis.com?
So when does the crashing occur and when you can record?
Driftwood Gamersyde
Thu Mar 26, 2020 2:55 pm
Done, hopefully it can be sorted out soon. :)
