RunnyPilot
PC Specification: Intel i5 4570, GTX 1060 6GB, Win 10 Pro
Mirillis Action Suggestion
Tue Mar 24, 2020 2:09 pm
I used to record with OBS quite a lot, but the issues I have with it is always lower framerate, and most notably, it starts to get choppy. I used Action quite a lot and never noticed lower framerate, but the only missing thing I notice is that, the additional audio is separate instead of being in the mp4 file. Can this be an option where I can put said separate audio in the mp4 file while recording? For example: An option called "Enable/Disable additional audio recording into mp4 file". It's kind of a bummer that I have to import it everytime in Resolve. Other than that, loving this software!
Re: Mirillis Action Suggestion
Wed Mar 25, 2020 9:35 am
Hello, to record audio along with the video just select Primary Audio Device option and set it to System Default. Also, go to Settings -> Audio and make sure that "Record Sound" option is enabled.
