GamerSaSsS
PC Specification: Win 10 Pro, Ryzen 7 2700x, GTX 1070ti
Update to v 4.3.1 Broke and Now Wont Record Anything
Sat Mar 28, 2020 4:29 pm
I use TimeShift to capture clips during live stream. Prior to latest update, I would open Xsplit, then open Action!, and once Action! was opened click back on Xsplit, it would show in the lower bar in Action! that it is monitoring Xsplit and I could capture clips with TimeShift no problem.
After update, that process no longer works. No matter what application I click on after opening Action!, I never get the update to the lower tool bar that it's monitoring any application and won't capture a clip at all. It doesn't even recognize when I click into a game.
So, at this point, Action! is no good to me for the purpose that I bought it. I went with Action! because I needed a reliable way to capture clips without taxing my system like Boom does.
I've reviewed every setting I can find, watched tutorials, but nothing works the way it should. Not sure if the recent update broke something, or if I should uninstall and reinstall or what. Just frustrated right now.
Re: Update to v 4.3.1 Broke and Now Wont Record Anything
Mon Mar 30, 2020 7:05 am
XSplit has been recently added to exclusions in Action!. What other applications are you trying to record?
GamerSaSsS
Tue Mar 31, 2020 2:00 pm
The only thing I use it for is my live streaming, which I use Xsplit for. Why was Xsplit excluded? Is OBS excluded as well? If not, why? I refuse to use OBS.
Mikeybrennan
PC Specification: 1700x rtx 2060 sc ultra
Sun Apr 12, 2020 5:08 pm
Were you able to figure out a solution? I been attempting to use timeshift while streaming but guessing it just doesn't work that way. Curious to attempting the xsplit but apparently its added to the exclusions.
