DragonDope
PC Specification: Windows 10, Ryzen 2600X, RX 590
Action 4.6 Crashing on Startup
Fri Apr 24, 2020 8:55 pm
Just like the topic said, it's crashing on startup. When I try to open it, an incomplete version of the UI appears for about 10 seconds before it just completely dies. I tried the uninstall thing from the FAQ on 4.5 and it didn't work, and I'm about to try it again on 4.6, but my expectations aren't very high. Running Windows 10 with a RX 590 (with up-to-date drivers) and Ryzen 2600X.
Something that I noticed is that 2 instances of action_svc.exe open whenever I try to open Action!, and they stick around indefinitely after the crash.
Re: Action 4.6 Crashing on Startup
Tue Apr 28, 2020 6:17 am
please provide us your PC DxDiag report. It will help us investigate your problem.
Click on, "Start Button".
Click on, "Run".
DragonDope
Tue Apr 28, 2020 2:40 pm
Sure thing, here ya go
DxDiag.zip
(14.43 KiB) Downloaded 646 times
Wed Apr 29, 2020 5:56 am
Install version 3.10.2 and see if it works: http://download.mirillis.com/files/acti ... _setup.exe
DragonDope
Wed Apr 29, 2020 3:38 pm
No dice. I've already uninstalled, deleted the registry key, restarted, and reinstalled to no avail. I also uploaded a video to show what my problem is visually: https://youtu.be/HdTEa-3FH6Y
Of course, I ran DxDiag again for you too.
DxDiag (2).zip
(14.62 KiB) Downloaded 617 times
Thu Apr 30, 2020 5:40 am
Are you using some sort of software that customize your taskbar and other windows layout?
If yes then it may be the reason. Try disabling this software and see if Action! works.
DragonDope
Thu Apr 30, 2020 2:49 pm
Yep, I just happened to chance upon that revelation yesterday. Turns out Window Blinds doesn't play well with Action at all. Dang.
3.10.2 is working now though, gonna try 4.6 again.
Thanks for your time!
