Osakawa
PC Specification: i7 6700K, GTX 980, Windows 10
4K is not working.
Sat May 23, 2020 6:35 pm
4K is working well on KMP but Splash can't run it properly. Splash shows the movie like there is a gray filter on it, but movie's preview tumbnail thing shows movie's colours well. Also while movie is playing, I can see some pixels when movements happen in the movie like when you forward the movie in VLC player and buffers the video and during that buffering some pixels show, same thing happens in here but I don't go forward the movie, it is just playing normal speed. You can see the gray filter thing image below and also MediaInfo below.
General
Unique ID : 277556289636729235917662840683020346106 (0xD0CF659E482741AD27ED6BBAED2EE2FA)
Complete name : D:\Movies\Tekli\Aquaman (2018) [2160p] [4K] [BluRay] [5.1] [YTS.MX]\Aquaman.2018.2160p.4K.BluRay.x265.10bit.AAC5.1-[YTS.MX].mkv
Format : Matroska
Format version : Version 4
File size : 6.94 GiB
Duration : 2 h 23 min
Overall bit rate : 6 929 kb/s
Writing application : Lavf58.41.100
Writing library : Lavf58.41.100
ErrorDetectionType : Per level 1
Video
Format : HEVC
Format/Info : High Efficiency Video Coding
Format profile : Main 10@L5@Main
Codec ID : V_MPEGH/ISO/HEVC
Width : 3 840 pixels
Height : 2 160 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Original frame rate : 23.976 FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 10 bits
Writing library : x265 3.3+4-30eb4de83092:[Linux][GCC 7.4.0][64 bit] 10bit
Encoding settings : cpuid=1111039 / frame-threads=3 / wpp / no-pmode / no-pme / no-psnr / no-ssim / log-level=2 / input-csp=1 / input-res=3840x2160 / interlace=0 / total-frames=0 / level-idc=0 / high-tier=1 / uhd-bd=0 / ref=4 / no-allow-non-conformance / no-repeat-headers / annexb / no-aud / no-hrd / info / hash=0 / no-temporal-layers / open-gop / min-keyint=23 / keyint=250 / gop-lookahead=0 / bframes=4 / b-adapt=2 / b-pyramid / bframe-bias=0 / rc-lookahead=25 / lookahead-slices=4 / scenecut=40 / hist-scenecut=0 / radl=0 / no-splice / no-intra-refresh / ctu=64 / min-cu-size=8 / rect / no-amp / max-tu-size=32 / tu-inter-depth=1 / tu-intra-depth=1 / limit-tu=0 / rdoq-level=2 / dynamic-rd=0.00 / no-ssim-rd / signhide / no-tskip / nr-intra=0 / nr-inter=0 / no-constrained-intra / strong-intra-smoothing / max-merge=3 / limit-refs=3 / limit-modes / me=3 / subme=3 / merange=57 / temporal-mvp / no-frame-dup / no-hme / weightp / no-weightb / no-analyze-src-pics / deblock=0:0 / sao / no-sao-non-deblock / rd=4 / selective-sao=4 / no-early-skip / rskip / no-fast-intra / no-tskip-fast / no-cu-lossless / no-b-intra / no-splitrd-skip / rdpenalty=0 / psy-rd=2.00 / psy-rdoq=1.00 / no-rd-refine / no-lossless / cbqpoffs=0 / crqpoffs=0 / rc=abr / bitrate=6000 / qcomp=0.60 / qpstep=4 / stats-write=0 / stats-read=2 / cplxblur=20.0 / qblur=0.5 / ipratio=1.40 / pbratio=1.30 / aq-mode=2 / aq-strength=1.00 / cutree / zone-count=0 / no-strict-cbr / qg-size=32 / no-rc-grain / qpmax=69 / qpmin=0 / no-const-vbv / sar=1 / overscan=0 / videoformat=5 / range=0 / colorprim=2 / transfer=2 / colormatrix=2 / chromaloc=0 / display-window=0 / cll=0,0 / min-luma=0 / max-luma=1023 / log2-max-poc-lsb=8 / vui-timing-info / vui-hrd-info / slices=1 / no-opt-qp-pps / no-opt-ref-list-length-pps / no-multi-pass-opt-rps / scenecut-bias=0.05 / hist-threshold=0.01 / no-opt-cu-delta-qp / no-aq-motion / no-hdr10 / no-hdr10-opt / no-dhdr10-opt / no-idr-recovery-sei / analysis-reuse-level=0 / analysis-save-reuse-level=0 / analysis-load-reuse-level=0 / scale-factor=0 / refine-intra=0 / refine-inter=0 / refine-mv=1 / refine-ctu-distortion=0 / no-limit-sao / ctu-info=0 / no-lowpass-dct / refine-analysis-type=0 / copy-pic=1 / max-ausize-factor=1.0 / no-dynamic-refine / no-single-sei / no-hevc-aq / no-svt / no-field / qp-adaptation-range=1.00 / no-scenecut-aware-qpconformance-window-offsets / right=0 / bottom=0
Default : Yes
Forced : No
Color range : Limited
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : A_AAC-2
Channel(s) : 6 channels
Channel layout : C L R Ls Rs LFE
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Writing library : Lavc58.75.100 libfdk_aac
Default : Yes
Forced : No
Text #1
Format : UTF-8
Codec ID : S_TEXT/UTF8
Codec ID/Info : UTF-8 Plain Text
Bit rate : 34 b/s
Count of elements : 1123
Stream size : 36.4 KiB (0%)
Title : English-SRT
Language : English
Default : Yes
Forced : No
Text #2
Format : UTF-8
Bit rate : 40 b/s
Count of elements : 1464
Stream size : 42.6 KiB (0%)
Title : English-SDH-SRT
Language : English
Default : No
Forced : No
Text #3
Format : PGS
Codec ID : S_HDMV/PGS
Codec ID/Info : Picture based subtitle format used on BDs/HD-DVDs
Default : No
Forced : No
Text #4
Format : PGS
Default : No
Forced : No
Text #5
Format : PGS
Duration : 2 h 15 min
Default : No
Forced : No
Text #6
Format : PGS
Default : No
Forced : No
Text #7
Format : PGS
Default : No
Forced : No
Text #8
Format : PGS
Default : No
Forced : No
Text #9
Format : PGS
Default : No
Forced : No
Text #10
Format : PGS
Default : No
Forced : No
Text #11
Format : PGS
Default : No
Forced : No
Text #12
Format : PGS
Default : No
Forced : No
Text #13
Format : PGS
Default : No
Forced : No
Text #14
Format : PGS
Default : No
Forced : No
Text #15
Format : PGS
Default : No
Forced : No
Text #16
Format : PGS
Default : No
Forced : No
Text #17
Format : PGS
Default : No
Forced : No
Text #18
Format : PGS
Default : No
Forced : No
Text #19
Format : PGS
Default : No
Forced : No
Text #20
Format : PGS
Default : No
Forced : No
Text #21
Format : PGS
Default : No
Forced : No
Text #22
Format : PGS
Default : No
Forced : No
Text #23
Format : PGS
Default : No
Forced : No
Text #24
Format : PGS
Default : No
Forced : No
Text #25
Format : PGS
Default : No
Forced : No
Text #26
Format : PGS
Default : No
Forced : No
Text #27
Format : PGS
Default : No
Forced : No
Text #28
Format : PGS
Default : No
Forced : No
Text #29
Format : PGS
Default : No
Forced : No
Text #30
Format : PGS
Default : No
Forced : No
Text #31
Format : PGS
Default : No
Forced : No
Text #32
Format : PGS
Default : No
Forced : No
Text #33
Format : PGS
Default : No
Forced : No
Re: 4K is not working.
Tue May 26, 2020 6:06 am
Go to Settings -> Video and disable hardware acceleration for video decoding.
Osakawa
Thu Jun 04, 2020 6:15 pm
Thank you, It solved my problem. However I think this is not the actual solution, because without gpu acceleration, cpu is in under a lot of usage like above the 80%. I think developer team need to update gpu acceleration, with gpu accel. video skipping is really smooth but under the cpu, It is a little bit laggy, difference can be seen easly. Since gpu accel. is not working well and causes gray filter thingy on video, I'm gonna use without it.
Return to “Splash 2.0”
