mata
PC Specification: Ryzen7 2700, 16GB, RX 580 4GB, W10 v2004
AMD AMF HEVC - kdenlive - flickering artifacts
Sun Jun 14, 2020 7:40 pm
Greetings,
I am using Action! version 4.9.0 to record Forza Horizon 4 game-play, using the MP4 file format and AMD AMF HEVC hardware acceleration (the video resolution is 1920*1200 at 60 FPS). The recordings turn out fine, the problems start to appear when I start editing the clips with kdenlive. As I trim parts of the recorded clips the preview gets progressively worse - a grey overlay appears accompanied by graphical artifacts.
After exporting the video (to lossless H.264 using libx264 and aac, as per default in kdenlive) the artifacts are preserved. I have added two captures from the resulting file.
Based on previous experience I think that some I frames get lost when the video clips are trimmed. Can this be prevented or remedied somehow? Is other software better equipped to handle the editing of clips recorded by Action! and AMD HW acceleration? Do you have some recommendations on configuration changes, be it the recording settings or kdenlive parametres, to work around this issue?
Thank you for your help in advance, kind regards,
Gyuszi
Re: AMD AMF HEVC - kdenlive - flickering artifacts
Tue Jun 16, 2020 7:00 am
could you please provide me a video sample where your issue occurs? Please upload your original video file (RAW) to one of the popular sharing sites like Google Drive or Dropbox. It will help us investigate your issue.
mata
Tue Jun 16, 2020 7:18 pm
I have uploaded three videos to my own server, the login credentials are action/action.
The three videos are - forza-sample-raw.mp4, which is the RAW file you asked for. As I mentioned in my original post, the recordings are fine, I am having problems editing them. This can be seen in the second video, titled screen-recording.mkv. Here, I used OBS to record my desktop to show what happens when I try and edit forza-sample-raw.mp4 using Kdenlive. The third and last video (test-encode.mp4)is the exported edit from Kdenlive.
Thank you for your help in advance!
Kind regards,
Julius
Wed Jun 17, 2020 6:04 am
Thank you for these files. Your video plays nicely in every player and YouTube converts it without problems. Maybe consider changing video editing software. Or try recording in AVC using AMD AMF hardware acceleration.
