Mjolkspam
PC Specification: Windows 7 Professional 64-bit
Action won't encode 100% of the video. (INVESTIGATING)
Tue Jan 31, 2012 1:45 am
Hello.
I got a slight problem when i'm going to export my game video i recorded.
I tested after a few times with a shorter video, it's about 6min long.
The export is doing well, taking some minutes, and doing all 100% done.
And i can even see in the little video screen that it has done all of the video,
but then when i check it in the folder where it is saved.
The video turns out to be only everything from 40sec - 1min 20sec. And all these green flickering (i know what that is tho).
So what i'm saying is that it wont export the video for 100%.
And before i press Start, i can see the size of the Output size, and its about 950MB.
But it says it like this: Output size: 950MB (12%).
What is those "(12%)"? Is that the length of the finish exported video or?
I dont understand why it only export a short bit of the video instead of all 6min.
Please help me with this. And ask for more info if you need it. And ill try to explain more.
Sorry for my sucky english here and there in the info :P
// Mjolkspam
Re: Action won't encode 100% of the video. (INVESTIGATING)
Sun Feb 26, 2012 9:27 pm
12% means that exported video size will be 12% of the original input file size.
The size will be reduced by 88%.
What is your CPU model?
Do you use hardware acceleration for video encoding?
What output exporting profile do you use and did you try to check with other profiles?
How much free space do you have on the disk where exported file is saved to?
Orphydian
PC Specification: Win 8 64 bit/I5 3.30 GHz/GTX 660 OC
Sat Apr 27, 2013 10:57 pm
