Abenyer
PC Specification: Laptop dell 7567 1050ti windows 10 I7
Webcam separate file it doesnt save
Thu Jun 25, 2020 12:06 am
Hi! I tried to record my screen and a separate file with the webcam but nonthing happens, only when i try the webcame only it does saves. I do know what to do, i tried all he things that throught my head
Re: Webcam separate file it doesnt save
Thu Jun 25, 2020 6:00 am
1. Uninstall Action!
4. Remove Action! catalog.
5. Reboot your PC.
Abenyer
Thu Jun 25, 2020 8:11 pm
Hi! I tried all of those steps but no one fixed it. :c i do not know, even now the preview of the camera didnt show it
P4C0T3
PC Specification: windows 8, AMD RADEON R7 M265, i7 5500U
Thu Oct 08, 2020 12:26 am
I'm having the same problem. I can record the webcam on the same file of the screen recording but when I choose to Record it on a separate video file (.avi) it doesn't work and it works as if I had selected the option to record the webcam only when the button is being pressed.
It happens for screen recording and for game recordings as well.
But this feature was working well for me a few months ago..
Watchman
Fri Oct 09, 2020 7:50 pm
Hi P4C0T3,
Just double checked this feature and it seems to work. We did not change enything in this area lately. I have selected MP4, record webcam to separate AVI. Two recordings are done MP4 + AVI and each have the same duration.
P4C0T3
Tue Oct 13, 2020 2:35 am
Hi P4C0T3,
Well, unfortunately it's not working for me.. I have no ideia what to do... :cry:
Is there any possible solution to this?
I've changed the webcam, used my DSLR camera as a webcam and it still doesn't work..
Watchman
Tue Oct 13, 2020 3:01 pm
Hi P4C0T3,
We have found this problem... When you enable recording webcam to separate file and select "Time-Shift" in Game mode then camera is invisible :( We have fixed this in v4.12.2 (we will release it tomorrow). I hope this is your case and we will be able to help you.
Shame on us :(
Watchman
Tue Oct 13, 2020 3:03 pm
For now in Time-Shift the camera is never recorded to a separate file as this requires two Time-Shifts (we are working on it).
