DanTheBlackWolf
PC Specification: Windows 10, Intel 5i, Nvidia GTX 1080Ti
Keybinds are a mess
Sat Jun 27, 2020 12:31 pm
OK, so I've been messing around with the trial version of Action! for a few days now, I'm trying to find a replacement to ShadowPlay since it's been giving me nothing but headaches. I'm not asking for much, nor do I need all the thousands of features Action like to promote. All I need to get started is a recorder with the keybinds I would use with ShadowPlay. Thing is Action won't let me use a Keybind combination if it is already being used. It just sits there like an idiot, and doesn't tell me why it won't read the input, no error, message or otherwise. After checking to see if my keyboard was busted, spoilers, it wasn't, I finally realized the problem. Ok, no issue, I've made a step forward. But you know what I could really use? An option to leave a keybind BLANK. I don't stream, I don't need links and overlays. Video games make it so when you click on a keybind for "interact", for example, and then pres ESC that keybind will be blank! No way to use that function. Why is there no option like that here? I've tried everything I could think of: ESC, BackSpace, DEL. Nothing. Can someone help?
On that note, is there an option to reset to default keybinds? I can't find that either.
Re: Keybinds are a mess
Mon Jun 29, 2020 8:39 am
You cannot assign same hotkey to different funcitons. Most of the hotkeys can be unchecked.
