hooke007
PC Specification: win10-RTX2070s-Adobe_rgb_display
Plz support Wide Color Gamut
Tue Jul 14, 2020 3:59 pm
I think it is definitely a important function. If the player does not support WCG monitor (such as bt2020/display-p3/adobe RGB), it will cause the problem of color distortion.
Watchman
Re: Plz support Wide Color Gamut
Fri Jul 17, 2020 9:12 pm
Splash detects monitor HDR/WCG and applies ST2084/BT2020 gamma for HEVC HDR10 video. It will not convert HDR to SDR though. We will add this soon in Splash 3.0
errifypeaceful
Tue Dec 30, 2025 4:42 am
I think this is definitely an important function. If the player does not support wide color gamut (WCG) monitors, such as BT.2020, Display-P3, or Adobe RGB, it can cause color distortion issues.
bloxfruits
PC Specification: Windows 11
Tue Jan 27, 2026 6:44 am
I agree.
Seraphina
PC Specification: Version 10.0.19045
Mon Mar 09, 2026 3:07 am
I think this is definitely an important feature. If a player’s monitor does not support WCG (such as BT.2020, Display-P3, or Adobe RGB), it may cause color distortion.
Return to “Splash 2.0”
