Watchman
How to capture ANY problematic (anti-cheat protected etc.) game
Fri Jul 17, 2020 1:46 pm
Hello everyone,
Below we explain how to capture (without any popup windows showing over) any game title without using Game Mode (that interacts with games internally):
1. Open Action and select Screen Mode
2. Add game or application executable name (like csgo.exe etc.) to excluded process list using Settings->Excluded process->Add (you need to find exe file location)
3. Start the game/application in fullscreen windowed mode
4. Scroll down to see "Application:" in Action (at the bottom of main view). Click select application. A window picker will popup. Select your game window from this picker (the game must not be minimized)
5. Check if game is visible on preview
6. Record/stream whatever. Only the game will be captured and no other windows that can pop over it as it can happen in fullscreen windowed mode
7. You should get even better performance and less frame drop than in game mode :) (we have tested it and usually get zero frame drop)
PS. This only works on Windows 10 version 1909 or newer
Link to video tutorial: https://youtu.be/LHku0JH6UDU
elonlilx
PC Specification: Windows 10
Re: How to capture ANY problematic (anti-cheat protected etc.) game
Mon Jun 23, 2025 8:23 am
Pribits
PC Specification: cpu
Sat Aug 23, 2025 2:28 am
I’ve always had issues with popups showing over my gameplay, so I’ll definitely try this method.
Tromen
PC Specification: 11
Wed Sep 03, 2025 9:51 am
Tried this with Apex and it seems smoother than Game Mode.
Deniseyrocker
Fri Sep 12, 2025 7:46 am
Having trouble remembering to add an exception for each game, anyone else? I usually forget until the overlay messes something up, then I frantically alt-tab out. It's happened to me multiple times in different games.
ordidfluid
PC Specification: Core i7, NVIDIA, Windows 11
Wed Oct 22, 2025 2:31 am
I was looking for a way to capture fullscreen windowed games without interruptions. It’s cool that this approach even improves performance.
RonaldBartlett
PC Specification: Intel Core i7-12700K
Mon Dec 08, 2025 4:14 am
This method makes capturing games in fullscreen windowed mode super smooth, avoids popup interruptions, and even improves performance without relying on Game Mode. Thanks for sharing the steps!
coeddie11
PC Specification: CPU model
Thu Feb 05, 2026 10:53 am
Thanks for the clear guide, this Screen Mode workaround is really helpful for anti-cheat–protected games and I can confirm it works smoothly on Windows 10 1909+ with better performance than Game Mode.
davismaria
PC Specification: Window 2016
Mon Apr 06, 2026 9:58 am
This guide on capturing games without popup windows is incredibly useful! It provides a straightforward method to record or stream gameplay while ensuring that only the game itself is captured, enhancing performance and reducing interruptions. Following these steps can help gamers achieve smoother recordings, especially in fullscreen windowed mode.
