crazylegs
PC Specification: windows 10 (2004), AMD 3950x, 2080
Support for Cam Link 4k?
Fri Jul 24, 2020 2:48 am
Hello Support team. I just got my cam link 4k. The option to use my camlink 4k is grayed out. I'm not able to select it as a web cam. All other application that use web cam can detect my cam link and DSLR with no issues. Does action have support for the Elgato Cam Link 4k? If so how can i select it?
Action
Action Version: 4.10.2
Recording Resolution: Original,
Recording Mode: Game, Screen, Cam Link 4k
Windows and Hardware
OS: Windows 10 (2004)
Video Card: NVIDIA 2080 Super
Video Driver Version: 451.67
CPU brand and model: AMD 3950 x
Motherboard brand and model: Gigabyte aurus Master x570
Memory: 32GB
Monitor Resolution: 1440p
Camera: DSLR Panasonic GH5
Capture Device: CAM LINK 4k
Problem Description
Game/App Problem: Cam Link 4k is grayed out
Watchman
Re: Support for Cam Link 4k?
Fri Jul 24, 2020 4:02 pm
Hi crazylegs,
We have filters for Elgato devices that's why it might got greyed out. Any chances we could upload 4.10.3 beta with Elgato Cam Link 4K so you could let us know if it works for you???
crazylegs
Fri Jul 24, 2020 5:31 pm
Sure i would like to try the 4.10.3 beta. Do you have a link where i can download the beta Action! app from?
crazylegs
Thu Jul 30, 2020 9:41 pm
Any update to this? Is there a beta action! 4 i can download and test?
crazylegs
Sat Aug 01, 2020 7:03 am
Ok so i got the Cam Link 4k partially working now. The issue seems to be that the support for the cam link 4k is limited to 1080p/60 or lower. Any resolution higher then that, then Action grays out the Cam Link 4k. not sure if this is by design or a bug. I was able to replicate the issue by using the "Device" capture mode. It was also limited to 1080p/60 max. I also upgraded my software to the new 4.10.3.
Is it possible to increase the support of the cam link 4k to allow its native resolution?
Hellmut
PC Specification: Intel I9 9980X; SLI RTX 2080 TI; Win 10
Only 1080p with CAM Link 4k (elgato) DSLR
Tue Nov 17, 2020 2:34 pm
Hi! This is old problem. Will you fix it?
Bandicam for example works in 4K with CAM Link.
Hellmut
Thu Dec 03, 2020 4:32 am
Hi! its been a wile. I want to up this topic and hear some reply. Please say something! If you can't add full 4K support - ok. It's fine for me. But it's not ok without answer!
And about Bandicam - Program can't support CamLink 4K. Only with huge color distortion.
Action! also can't work with Webcam above 1080p (program stuck or image of webcam).
Hellmut
Tue Mar 09, 2021 9:00 am
Hi again after several months. What's up with this problem? Maybe you'll add 4k Cam support in Action 5.0? Thank you!
Watchman
Tue Mar 09, 2021 10:43 pm
Cam Link 4K support will be available soon in Action! 5.
PS. Even now Action! support Avermedia and Elgato cards in 4K HDR for recording and streaming so 1080p should not be a problem.
Hellmut
Wed Mar 10, 2021 4:25 am
Thank you. I've been waiting for this since Fall 2020.
Users browsing this forum: No registered users and 54 guests
