Aleksandar030
PC Specification: FX8300, RX 580 4 GB, Windows 7 64bit
No Man's Sky Recording Issues
Mon Jul 27, 2020 8:27 pm
Hi guys,
Just thought you might want to take a look @ No Man's Sky which is a fairly popular game. I'm copying this info from the forum so you understand better what's happening.
I'm using latest AMD drivers & Action! as of 27th July 2020.
OS: Windows 7 64bit
Video Card: AMD RX580
Memory: 4 GB
Monitor Resolution: 1920x1080
Video Editor: Power Director (not relevant since we can't even record the game)
Game Problem: No Man's Sky
Video Type: MP4
It basically crashes the game regardless of whether you use 'game' or 'screen' mode. This is a bit weird since it used to work before with 'screen' (only 'game' mode was a problem).
Can you guys patch this up in the next update? Would be much appreciated!
Thanks.
Re: No Man's Sky Recording Issues
Tue Jul 28, 2020 6:14 am
Go to C:\Users\%username%\AppData\Local\Temp. Find NMS.txt file and send it to us.
Aleksandar030
Sun Aug 02, 2020 1:17 pm
I have the following files there:
https://ibb.co/kSH8Wwg
When we open the NMS_action.log there's:
DLL_PROCESS_ATTACH (UWP: 0)
VULKAN present seen
Is there anything else you need?
I just remembered maybe I can set the game as windowed and use 'screen' to record. But still, it would be nice if this could be fixed in some update.
If you need anything else, do let me know.
Aleksandar030
Tue Aug 04, 2020 7:58 pm
Actually the game seems to crash with windowed + screen for recording as well. Hotfix would be appreciated.
Aleksandar030
Mon Aug 10, 2020 2:31 pm
Any news?
Aleksandar030
Wed Aug 19, 2020 9:02 pm
You probably missed it so I'll send it up top again. Any news? Thanks!
Thu Aug 20, 2020 6:02 am
Press Start and then type "Regedit" in search and press Enter.
Go to the following path: HKEY_LOCAL_MACHINE\SOFTWARE\Khronos\Vulkan\ImplicitLayers
Remove etries that have "MirillisActionVulkanLayer.json" in its name.
Start Action! again and see if the game works.
Aleksandar030
Thu Aug 20, 2020 3:30 pm
The game works until I press 'record' via my keyboard which then crashes. tried all combos between recording the 'game' and 'screen' and the game being borderless and full screen etc. Disabling mods and all that. Always the same. I'll just use AMD's ReLive for NMS, it's fine. Thanks for trying to help.
