SaxaphoneWalrus
PC Specification: i7 8700K, RTX 2080, Windows 10
Action! Crashes Paint.net
Mon Jul 27, 2020 8:36 pm
If Action! is open when opening Paint.net, or if you have Paint.net open and then open Action! Paint.net crashes and says that Action! may be the problem (as it seems to be).
Also wondering why the updater for 4.10.2.0 fails to update (I was on an older version but I cannot remember which, I think it might have been 4.8-4.9, but I don't know.) when it never did this before.
Re: Action! Crashes Paint.net
Tue Jul 28, 2020 6:15 am
Try adding Paint.net to exclusions in Action! and see if it works.
SaxaphoneWalrus
Tue Jul 28, 2020 2:28 pm
That works, thank you.
