Benezer
PC Specification: Windows 10, I-7 7th Gen, GTX 1050
Not Supported Video Format By Sony Vegas
Sun Aug 02, 2020 4:30 pm
So i was recording with the MP4 format instead of the AVI. But the problem is, AVI always cause my game frame rate to drop so I use mp4 instead. But the problem is i couldn't import it to vegas and it said that the file format is supported. Can anybody help? I'm clueless here. Thank you
Re: Not Supported Video Format By Sony Vegas
Mon Aug 03, 2020 8:39 am
Please provide us a MediaInfo report of your file. To do this please download (it's free) MediaInfo from here: http://mediaarea.net/en/MediaInfo. Once you have installed MediaInfo please go to your file location and right-click on it. Select MediaInfo. A new Windows with basic information should pop-up. Below you can find more information. Click the button and select "Tree" option. Advanced information will be displayed. Please export the report or simply create a screenshot of your Tree view.
