KarliN
PC Specification: Intel(R) Core(TM) i5-2400 CPU @ 3.10 GHz
[RESOLVED]CSGO crashes on action! record
Thu Aug 27, 2020 11:16 am
EDIT: I don't know which patch but now, CS:GO doesn't crash with mirillis action. One catch though. Kill cam still cause crashes time to time so you need to turn auto kill cam option off in-game. Thank you developers! :D
Hello.
I recently started playing CS:GO again, an old game. When I start recording by using Mirillis Action! the game crashes. Is it because CS:GO is an old game? I'd love it if there's some kind of a patch or way to fix this problem. Below is my Mirillis action setting.
SCREEN and GAME (Both crashes CS:GO)
MP4, NVIDIA NVENC HEVC, 1080p, 60FPS, VFR
Please and thank you.
Re: CSGO crashes on action! record
Fri Aug 28, 2020 5:52 am
Hello.
I have just checked the game and everything works. Which Action! version do you use? What are the video settings in the game?
c0urier
PC Specification: Ryzen 3600X, GTX 1070, Win10 2004
Mon Sep 07, 2020 12:48 pm
I can confirm this, CS:GO crashes everytime I try to record. It happened with earlier versions also, I can't actually recall when it worked the last time.
Any help would be greatly appreciated.
Action! 4.10.5 Full
Happens with: Action! 4.11 Full also
Br c0urier
OS: Windows 10 - 2004
Mirillis Action!: 4.11 Full verion
CPU: AMD Ryzen 3600X
Video Card: Nvidia GeForce® GTX 1070 WINDFORCE OC 8G
Memory: 32 GB
Monitor Resolution: 1920x1080
Video Editor: Blender
Video Type: MP4
c0urier
Fri Sep 11, 2020 9:55 am
Just did a complete uninstallation of Action! and installed Action! 4.11 - Same result.
As soon as I start recording/streaming CSGO crashes.
Any advice would be greatly appreciated.
Br c0urier
Memory: 32 GB
Video Type: MP4
Tue Sep 15, 2020 5:52 am
Click on, "Start Button".
Click on, "Run".
c0urier
Tue Sep 15, 2020 12:16 pm
Since I can't post the text file, I get an error I have zipped it.
DxDiag.zip
(14.07 KiB) Downloaded 821 times
Br c0urier
Memory: 32 GB
Video Type: MP4
Wed Sep 16, 2020 5:44 am
The game doesn't crash but hangs. Is there some other software that may be interfering with the game?
c0urier
Mon Sep 21, 2020 8:02 pm
Non, even if all other processes are closed this happens.
Br c0urier
Memory: 32 GB
Video Type: MP4
KarliN
Tue Sep 22, 2020 1:56 pm
If you change your cs:go video setting from fullscreen to fullscreen windowed, action works. I hope in the near future action will work fine in cs:go's fullscreen mode.
Thank you anyways.
KarliN
Tue Sep 22, 2020 5:34 pm
Wait, just checked and somehow it crashes on Fullscreen windows as well. I don't know what is wrong with this game and action. Is this because CS:GO is using dx9 or is it because cs:go has its very unique programming underneath it? Anyway, since developer said it works fine on their end I guess I'll need to work with video settings or whatever. By the way, my action's version is 4.10.5. Thank you.
