matty89
PC Specification: AMD Ryzen 5 2600X Card: GTX 1060 6GB
Elgato HD50 S Footage Issues
Mon Aug 31, 2020 2:04 pm
Hi
When im recording footage from my Elgato HD60S card im having issues with the footage, when i look back at the recording the footage is choppy and not smooth
When i record the same game but the PC version the footage is fine on there
I dont want to get a new capture card if thats not the porblem has anyone got any ideas
I have even moved to the lowest settings on Action and the issue is still there
Re: Elgato HD50 S Footage Issues
Tue Sep 01, 2020 6:04 am
Could you please provide us video sample where this issue occurs?
matty89
Tue Sep 01, 2020 11:01 am
Here is a link to some footage via one drive
https://1drv.ms/v/s!AnaAwrbfSb9TswFaW7a ... O?e=6RRZNs
you can see it stutters a lot and seems to lose FPS at times aswell
Wed Sep 02, 2020 6:28 am
Your video does not stutter for me. It is not ideal but video has a constant framerate 60 fps. That means the problem may be with the device itself.
matty89
Wed Sep 02, 2020 9:56 am
So you can also see its not smooth yeah ?
Thu Sep 03, 2020 5:56 am
Most of the time the video is fluid. Sometimes there is an duplicated frame.
matty89
Thu Sep 03, 2020 10:50 am
So do you think this is the Elgato thats causing this
