Edius
PC Specification: intel 8700, rtx2070super, WINDOWS 10 pro
Monflo Server isn't working
Wed Sep 23, 2020 7:12 am
I can't start Monflo Server, the program closes and gives this error: Failed to initialize product. Tried on another computer the same problem. https://fex.net/ru/s/esvp4b7
Re: Monflo Server isn't working
Thu Sep 24, 2020 5:57 am
It looks like Monflo has not been installed properly. What antivirus software do you use?
Edius
Thu Sep 24, 2020 7:31 am
Thank you for your response I'm using Kaspersky but when I used to free version Monflo it's problem was not. Now I deleted antivirus with the program and installed Monflo as new but the same problem.
Fri Sep 25, 2020 6:08 am
Zip the whole Monflo folder and send it to us.
Edius
Fri Sep 25, 2020 8:05 am
I sent two archives from home and from work. Computer at work ( ryzan 3700x and 1660 super ) https://fex.net/ru/s/epcl6ld
Edius
Tue Sep 29, 2020 11:15 am
I've resolved this problem reinstalling windows on both computers and now Monflo works well. Only one from it launches only from the Desktop, Monoflo with the menu Start not working
Watchman
Sun Oct 04, 2020 6:39 pm
Hi Edius,
Please check for a BIG Monflo update next week.
Edius
Mon Oct 05, 2020 9:20 am
Thanks. I will be waiting with eager!
Edius
Mon Oct 19, 2020 6:26 pm
Hi Edius,
Hello! How about a big update?
Watchman
Sun Mar 07, 2021 2:46 am
Version 3.0.0 will be release tomorrow (old GUI but near zero lag for 1080p and 16ms for 4K). The next will be "Remotly" it will replace Monflo with a new design and many new cool features.
Return to “Monflo - Remote PC Access and Gaming”
