oskoa
PC Specification: W10, Ryzen 3 3200G, 16 GB, GTX 1070
Webcam files are too much big
Fri Oct 30, 2020 3:49 am
hello. When i use Webcam by separate files, the file size of the Webcam are insanely Bigger (Bitrate: 34 MBS) for only a webcam file. I ussualy render videos in 1280*720 in 20 mbps (60 fps) or 10 mbps if videos are in 30 FPS.
Can i reduce the file size? the idea is record already compressed. I can use an external software to convert, but the file its too much in longs recordings (40+ GB maybe for each video, and for only the webcam file!)
my webcam its Logitech C270, and i have 4.1 version.
Re: Webcam files are too much big
Fri Oct 30, 2020 7:14 am
We are using our own codec to record webcam in a separate file. It is very fast and quality is very good but files can be very large. By using our codec we don't have to create second encoder on GPU or CPU. You can use Action's export feature to convert AVI file to MP4.
