mpj4
PC Specification: Toshiba Satellite L55-B Windows 10
Action not appearing
Mon Nov 09, 2020 6:04 am
I bought action a few years ago and decided to use it again because I wanted to record something real quick and didn't want to set up obs. I reinstalled the program and running version 4.12.2. Clicking the program shows a splash screen with "loading modules" loading bar at the bottom. After the splash screen disappears nothing happens. Pls help.
Re: Action not appearing
Tue Nov 10, 2020 6:59 am
Click on, "Start Button".
Click on, "Run".
Pyron619
PC Specification: Ryzen 9 3950x - RTX 2080 - Windows 10
Sat Nov 14, 2020 7:20 am
I have the same issue of this guy. Splash screen stay loading modules forever.
This is the DxDiag
System Information
Time of this report: 11/14/2020, 07:08:04
Machine name: DESKTOP-RP8L8CO
Machine Id: {2B9A630B-5A2C-4473-9D35-66E3A8FD527A}
Operating System: Windows 10 Home 64-bit (10.0, Build 18363) (18362.19h1_release.190318-1202)
Language: English (Regional Setting: English)
System Manufacturer: System manufacturer
System Model: System Product Name
BIOS: 0702 (type: UEFI)
Processor: AMD Ryzen 9 3950X 16-Core Processor (32 CPUs), ~3.5GHz
Memory: 32680MB RAM
Available OS Memory: 32680MB RAM
Page File: 7059MB used, 30484MB available
Windows Dir: C:\Windows
DirectX Version: DirectX 12
DX Setup Parameters: Not found
User DPI Setting: 96 DPI (100 percent)
System DPI Setting: 96 DPI (100 percent)
DWM DPI Scaling: Disabled
Miracast: Available, with HDCP
Microsoft Graphics Hybrid: Not Supported
DirectX Database Version: Unknown
DxDiag Version: 10.00.18362.0387 64bit Unicode
DxDiag Previously: Crashed in system information (stage 3) & Direct3D (stage 2). Re-running DxDiag with "dontskip" command line parameter or choosing not to bypass information gathering when prompted might result in DxDiag successfully obtaining this information
DxDiag Notes
Display Tab 1: No problems found.
Sound Tab 1: No problems found.
Sound Tab 2: No problems found.
Sound Tab 3: No problems found.
Sound Tab 4: The file vbaudio_cable64_win7.sys is not digitally signed, which means that it has not been tested by Microsoft's Windows Hardware Quality Labs (WHQL). You may be able to get a WHQL logo'd driver from the hardware manufacturer.
Input Tab: No problems found.
DirectX Debug Levels
Direct3D: 0/4 (retail)
DirectDraw: 0/4 (retail)
DirectInput: 0/5 (retail)
DirectMusic: 0/5 (retail)
DirectPlay: 0/9 (retail)
DirectSound: 0/5 (retail)
DirectShow: 0/6 (retail)
Display Devices
Card name: NVIDIA GeForce RTX 2080
Manufacturer: NVIDIA
Chip type: GeForce RTX 2080
DAC type: Integrated RAMDAC
Device Type: Full Device (POST)
Device Key: Enum\PCI\VEN_10DE&DEV_1E87&SUBSYS_37B31458&REV_A1
Device Status: 0180200A [DN_DRIVER_LOADED|DN_STARTED|DN_DISABLEABLE|DN_NT_ENUMERATOR|DN_NT_DRIVER]
Device Problem Code: No Problem
Driver Problem Code: Unknown
Display Memory: Unknown
Dedicated Memory: n/a
Shared Memory: n/a
Current Mode: 1920 x 1080 (32 bit) (150Hz)
HDR Support: Not Supported
Display Topology: Internal
Display Color Space: Unknown
Color Primaries: Unknown
Display Luminance: Unknown
Monitor Name: Dell S2417DG(DisplayPort)
Monitor Model:
Monitor Id:
Native Mode:
Output Type:
Monitor Capabilities: HDR Not Supported
Display Pixel Format: DISPLAYCONFIG_PIXELFORMAT_32BPP
Advanced Color: Not Supported
Driver Name: C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_5dcb5bbf5c3edcf2\nvldumdx.dll,C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_5dcb5bbf5c3edcf2\nvldumdx.dll,C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_5dcb5bbf5c3edcf2\nvldumdx.dll,C:\Windows\System32\DriverStore\FileRepository\nv_dispi.inf_amd64_5dcb5bbf5c3edcf2\nvldumdx.dll
Driver File Version: Unknown (Unknown)
Driver Version: 27.21.14.5730
DDI Version: Unknown
Feature Levels: Unknown
Driver Model: WDDM 2.6
Graphics Preemption: Pixel
Compute Preemption: Dispatch
Miracast: Not Supported by Graphics driver
Detachable GPU: No
Hybrid Graphics GPU: Not Supported
Power P-states: Not Supported
Virtualization: Paravirtualization
Block List: No Blocks
Catalog Attributes: Universal:False Declarative:True
Driver Attributes: Final Retail
Driver Date/Size: Unknown, 0 bytes
WHQL Logo'd: n/a
WHQL Date Stamp: n/a
Device Identifier: Unknown
Vendor ID: 0x10DE
Device ID: 0x1E87
SubSys ID: 0x37B31458
Revision ID: 0x00A1
Driver Strong Name: oem3.inf:0f066de3ed20de7a:Section001:27.21.14.5730:pci\ven_10de&dev_1e87
Rank Of Driver: 00CF2001
Video Accel: Unknown
DXVA2 Modes: Unknown
Deinterlace Caps: n/a
D3D9 Overlay: Unknown
DXVA-HD: Unknown
DDraw Status: Disabled
D3D Status: Not Available
AGP Status: Not Available
MPO MaxPlanes: Unknown
MPO Caps: Unknown
MPO Stretch: Unknown
MPO Media Hints: Unknown
MPO Formats: Unknown
PanelFitter Caps: Unknown
PanelFitter Stretch: Unknown
Sound Devices
Description: Headphones 7.1 (Logitech PRO X Gaming Headset)
Default Sound Playback: Yes
Default Voice Playback: Yes
Hardware ID: USB\VID_046D&PID_0AAA&REV_0031&MI_00
Manufacturer ID: 65535
Product ID: 65535
Type: WDM
Driver Name: USBAUDIO.sys
Driver Version: 10.00.18362.0997 (English)
WHQL Logo'd: Yes
Date and Size: 02/10/2020 00:00:00, 198656 bytes
Other Files:
Driver Provider: Logitech
HW Accel Level: Basic
Cap Flags: 0xF1F
Min/Max Sample Rate: 100, 200000
Static/Strm HW Mix Bufs: 1, 0
Static/Strm HW 3D Bufs: 0, 0
HW Memory: 0
Voice Management: No
EAX(tm) 2.0 Listen/Src: No, No
I3DL2(tm) Listen/Src: No, No
Sensaura(tm) ZoomFX(tm): No
Description: Realtek Digital Output (Realtek(R) Audio)
Default Sound Playback: No
Default Voice Playback: No
Hardware ID: HDAUDIO\FUNC_01&VEN_10EC&DEV_1220&SUBSYS_104387C4&REV_1001
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: RTKVHD64.sys
Driver Version: 6.00.8702.0001 (English)
WHQL Logo'd: Yes
Date and Size: 13/05/2019 00:00:00, 6848600 bytes
Other Files:
Driver Provider: Realtek Semiconductor Corp.
Cap Flags: 0xF1F
HW Memory: 0
Description: Speakers (Yeti Stereo Microphone)
Hardware ID: USB\VID_B58E&PID_9E84&REV_0100&MI_00
Product ID: 65535
Type: WDM
WHQL Logo'd: Yes
Date and Size: 17/07/2020 00:00:00, 198656 bytes
Other Files:
Driver Provider: Microsoft
Cap Flags: 0xF1F
HW Memory: 0
Description: VoiceMeeter Aux Input (VB-Audio Virtual Cable)
Hardware ID: VBAudioVACWDM
Manufacturer ID: 1
Product ID: 100
Type: WDM
Driver Name: vbaudio_cable64_win7.sys
Driver Version: 6.01.7600.16385 (English)
WHQL Logo'd: No
Date and Size: 02/09/2014 00:00:00, 41192 bytes
Other Files:
Driver Provider: VB-Audio Software
Cap Flags: 0xF1F
HW Memory: 0
Sound Capture Devices
Description: Microphone (Logitech PRO X Gaming Headset)
Default Sound Capture: Yes
Default Voice Capture: No
Date and Size: 8/12/2020 22:58:04, 198656 bytes
Cap Flags: 0x1
Format Flags: 0xFFFFF
Description: Microphone (Yeti Stereo Microphone)
Default Sound Capture: No
Default Voice Capture: Yes
Cap Flags: 0x1
Description: VoiceMeeter Aux Output (VB-Audio Virtual Cable)
Date and Size: 9/2/2014 17:01:16, 41192 bytes
Cap Flags: 0x1
Video Capture Devices
Number of Devices: 0
DirectInput Devices
Device Name: Mouse
Attached: 1
Controller ID: n/a
Vendor/Product ID: n/a
FF Driver: n/a
Device Name: Keyboard
Attached: 1
Controller ID: n/a
FF Driver: n/a
Device Name: PRO X
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0x0AAA
FF Driver: n/a
Device Name: G502 HERO Gaming Mouse
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x046D, 0xC08B
FF Driver: n/a
Device Name: PRO X
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: Yeti Stereo Microphone
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0xB58E, 0x9E84
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: AURA LED Controller
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x0B05, 0x18F3
FF Driver: n/a
Device Name: SteelSeries Apex Pro
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x1038, 0x1610
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: ROG_RYUJIN
Attached: 1
Controller ID: 0x0
Vendor/Product ID: 0x0B05, 0x18AE
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: PRO X
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Device Name: PRO X
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Attached: 1
Controller ID: 0x0
FF Driver: n/a
Poll w/ Interrupt: No
USB Devices
+ USB Root Hub (USB 3.0)
| Vendor/Product ID: 0x1022, 0x149C
| Matching Device ID: USB\ROOT_HUB30
| Service: USBHUB3
| Driver: USBHUB3.SYS, 5/13/2020 10:13:05, 634680 bytes
+-+ Generic USB Hub
| | Vendor/Product ID: 0x174C, 0x2074
| | Matching Device ID: USB\USB20_HUB
| | Service: USBHUB3
| +-+ USB Composite Device
| | | Matching Device ID: USB\COMPOSITE
| | | Service: usbccgp
| | | Driver: usbccgp.sys, 10/15/2020 09:34:18, 183616 bytes
| | +-+ SteelSeries Apex Pro
| | | | Matching Device ID: usb\vid_1038&pid_1610&mi_00
| | | | Lower Filters: sshid
| | | | Service: mshidkmdf
| | | | Driver: sshid.sys, 7/24/2020 15:48:08, 48936 bytes
| | | | Driver: engineco.dll, 7/24/2020 15:48:04, 305376 bytes
| | | | Driver: engineinstallpkg.exe, 7/24/2020 15:48:06, 30816 bytes
| | | +-+ HID-compliant mouse
| | | | | Matching Device ID: HID_DEVICE_SYSTEM_MOUSE
| | | | | Service: mouhid
| | | | | Driver: mouhid.sys, 3/19/2019 04:43:43, 35840 bytes
| | | | | Driver: mouclass.sys, 3/19/2019 04:43:43, 66872 bytes
| | | +-+ HID Keyboard Device
| | | | | Matching Device ID: HID_DEVICE_SYSTEM_KEYBOARD
| | | | | Service: kbdhid
| | | | | Driver: kbdhid.sys, 3/19/2019 04:43:43, 46592 bytes
| | | | | Driver: kbdclass.sys, 3/19/2019 04:43:43, 70968 bytes
| | | | Matching Device ID: usb\vid_1038&pid_1610&mi_02
| | | | Service: mshidkmdf
| | | | | Service: mouhid
| | | | | Service: kbdhid
| | +-+ USB Input Device
| | | | Matching Device ID: USB\Class_03
| | | | Service: HidUsb
| | | | Driver: hidusb.sys, 4/11/2020 16:06:15, 45568 bytes
| | | | Driver: hidclass.sys, 4/11/2020 16:06:15, 211968 bytes
| | | | Driver: hidparse.sys, 4/11/2020 16:06:15, 46080 bytes
| | | | | Service: mouhid
| | Service: usbccgp
| | | Matching Device ID: USB\Class_03&SubClass_01
| | | Service: HidUsb
| | | | Service: mouhid
| | | Service: HidUsb
| | | | Service: kbdhid
Gameport Devices
PS/2 Devices
| Vendor/Product ID: 0x1B1C, 0x0000
| Service: kbdhid
DirectShow Filters
DirectShow Filters:
WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,10.00.18362.1082
WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,10.00.18362.1082
WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,10.00.18362.0001
MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,10.00.18362.0001
Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,10.00.18362.1016
WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,10.00.18362.0001
WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,10.00.18362.1139
Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,10.00.18362.0001
Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,10.00.18362.0001
DV Muxer,0x00400000,0,0,qdv.dll,10.00.18362.0001
Color Space Converter,0x00400001,1,1,quartz.dll,10.00.18362.0900
WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.18362.0001
AVI Splitter,0x00600000,1,1,quartz.dll,10.00.18362.0900
VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,10.00.18362.0900
SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,10.00.18362.0001
XSplitMJPEGDecoder,0x00200002,1,1,,
Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,10.00.18362.1198
AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,10.00.18362.0900
XSplitQsMJPEGDecoder,0x00200001,1,1,,
StreamBufferSink,0x00200000,0,0,sbe.dll,10.00.18362.0001
MJPEG Decompressor,0x00600000,1,1,quartz.dll,10.00.18362.0900
MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,10.00.18362.0900
SAMI (CC) Parser,0x00400000,1,1,quartz.dll,10.00.18362.0900
VBI Codec,0x00600000,1,4,VBICodec.ax,10.00.18362.0001
MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,10.00.18362.0900
Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,10.00.18362.0001
SBE2FileScan,0x00200000,0,0,sbe.dll,10.00.18362.0001
Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.18362.0001
Internal Script Command Renderer,0x00800001,1,0,quartz.dll,10.00.18362.0900
MPEG Audio Decoder,0x03680001,1,1,quartz.dll,10.00.18362.0900
DV Splitter,0x00600000,1,2,qdv.dll,10.00.18362.0001
Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,10.00.18362.0900
Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,10.00.18362.0001
ACM Wrapper,0x00600000,1,1,quartz.dll,10.00.18362.0900
Video Renderer,0x00800001,1,0,quartz.dll,10.00.18362.0900
MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,10.00.18362.0001
Line 21 Decoder,0x00600000,1,1,,
Video Port Manager,0x00600000,2,1,quartz.dll,10.00.18362.0900
Video Renderer,0x00400000,1,0,quartz.dll,10.00.18362.0900
VPS Decoder,0x00200000,0,0,WSTPager.ax,10.00.18362.0001
WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.18362.0001
VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,
File writer,0x00200000,1,0,qcap.dll,10.00.18362.0001
XSplitFFDecoder,0x00200001,1,1,,
DVD Navigator,0x00200000,0,3,qdvd.dll,10.00.18362.0900
Overlay Mixer2,0x00200000,1,1,,
AVI Draw,0x00600064,9,1,quartz.dll,10.00.18362.0900
Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,10.00.18362.0001
WST Pager,0x00200000,1,1,WSTPager.ax,10.00.18362.0001
MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,10.00.18362.0900
DV Video Decoder,0x00800000,1,1,qdv.dll,10.00.18362.0001
SampleGrabber,0x00200000,1,1,qedit.dll,10.00.18362.0900
Null Renderer,0x00200000,1,0,qedit.dll,10.00.18362.0900
MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,10.00.18362.0001
Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,10.00.18362.0001
StreamBufferSource,0x00200000,0,0,sbe.dll,10.00.18362.0001
Smart Tee,0x00200000,1,2,qcap.dll,10.00.18362.0001
Overlay Mixer,0x00200000,0,0,,
AVI Decompressor,0x00600000,1,1,quartz.dll,10.00.18362.0900
AVI/WAV File Source,0x00400000,0,2,quartz.dll,10.00.18362.0900
Wave Parser,0x00400000,1,1,quartz.dll,10.00.18362.0900
MIDI Parser,0x00400000,1,1,quartz.dll,10.00.18362.0900
Multi-file Parser,0x00400000,1,1,quartz.dll,10.00.18362.0900
File stream renderer,0x00400000,1,1,quartz.dll,10.00.18362.0900
Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,10.00.18362.0001
StreamBufferSink2,0x00200000,0,0,sbe.dll,10.00.18362.0001
AVI Mux,0x00200000,1,0,qcap.dll,10.00.18362.0001
Line 21 Decoder 2,0x00600002,1,1,quartz.dll,10.00.18362.0900
File Source (Async.),0x00400000,0,1,quartz.dll,10.00.18362.0900
File Source (URL),0x00400000,0,1,quartz.dll,10.00.18362.0900
Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,10.00.18362.0001
Enhanced Video Renderer,0x00200000,1,0,evr.dll,10.00.18362.0001
BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,10.00.18362.0001
MPEG Video Decoder,0x40000001,1,1,quartz.dll,10.00.18362.0900
WDM Streaming Tee/Splitter Devices:
Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,10.00.18362.0001
Video Compressors:
WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,10.00.18362.0001
WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,10.00.18362.0001
MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,10.00.18362.0001
DV Video Encoder,0x00200000,0,0,qdv.dll,10.00.18362.0001
MJPEG Compressor,0x00200000,0,0,quartz.dll,10.00.18362.0900
Audio Compressors:
WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,10.00.18362.1082
WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,10.00.18362.1082
IMA ADPCM,0x00200000,1,1,quartz.dll,10.00.18362.0900
Microsoft ADPCM,0x00200000,1,1,quartz.dll,10.00.18362.0900
GSM 6.10,0x00200000,1,1,quartz.dll,10.00.18362.0900
CCITT A-Law,0x00200000,1,1,quartz.dll,10.00.18362.0900
CCITT u-Law,0x00200000,1,1,quartz.dll,10.00.18362.0900
MPEG Layer-3,0x00200000,1,1,quartz.dll,10.00.18362.0900
Audio Capture Sources:
Microphone (Logitech PRO X Gaming Headset),0x00200000,0,0,qcap.dll,10.00.18362.0001
XSplitBroadcaster,0x00200000,0,1,XSplitBroadcasterCam.dll,1.00.2006.1701
Microphone (Yeti Stereo Microphone),0x00200000,0,0,qcap.dll,10.00.18362.0001
VoiceMeeter Aux Output (VB-Audio Virtual Cable),0x00200000,0,0,qcap.dll,10.00.18362.0001
PBDA CP Filters:
PBDA DTFilter,0x00600000,1,1,CPFilters.dll,10.00.18362.1139
PBDA ETFilter,0x00200000,0,0,CPFilters.dll,10.00.18362.1139
PBDA PTFilter,0x00200000,0,0,CPFilters.dll,10.00.18362.1139
Midi Renderers:
Default MidiOut Device,0x00800000,1,0,quartz.dll,10.00.18362.0900
Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,10.00.18362.0900
WDM Streaming Capture Devices:
Realtek HD Audio Mic input,0x00200000,1,1,ksproxy.ax,10.00.18362.0001
Realtek HD Audio Stereo input,0x00200000,1,1,ksproxy.ax,10.00.18362.0001
Realtek HD Audio Line input,0x00200000,1,1,ksproxy.ax,10.00.18362.0001
Yeti Stereo Microphone,0x00200000,2,2,ksproxy.ax,10.00.18362.0001
VB-Audio Point,0x00200000,2,2,ksproxy.ax,10.00.18362.0001
PRO X,0x00200000,2,2,ksproxy.ax,10.00.18362.0001
,0x00000000,0,0,,
WDM Streaming Rendering Devices:
Realtek HDA SPDIF Out,0x00200000,1,1,ksproxy.ax,10.00.18362.0001
Realtek HD Audio output,0x00200000,1,1,ksproxy.ax,10.00.18362.0001
,0x00000000,0,0,,
BDA Network Providers:
Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.18362.0001
Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.18362.0001
Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.18362.0001
Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,10.00.18362.0001
Microsoft Network Provider,0x00200000,0,1,MSNP.ax,10.00.18362.0001
Video Capture Sources:
Camera (NVIDIA Broadcast),0x00200000,0,1,NvVirtualCameraFilter_x64.dll,1.00.0000.0030
Multi-Instance Capable VBI Codecs:
BDA Transport Information Renderers:
BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,10.00.18362.0001
MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,10.00.18362.0001
WDM Streaming Communication Transforms:
Audio Renderers:
Headphones 7.1 (Logitech PRO X Gaming Headset),0x00200000,1,0,quartz.dll,10.00.18362.0900
Default DirectSound Device,0x00800000,1,0,quartz.dll,10.00.18362.0900
Default WaveOut Device,0x00200000,1,0,quartz.dll,10.00.18362.0900
DirectSound: Realtek Digital Output (Realtek(R) Audio),0x00200000,1,0,quartz.dll,10.00.18362.0900
DirectSound: Speakers (Yeti Stereo Microphone),0x00200000,1,0,quartz.dll,10.00.18362.0900
DirectSound: VoiceMeeter Aux Input (VB-Audio Virtual Cable),0x00200000,1,0,quartz.dll,10.00.18362.0900
DirectSound: Headphones 7.1 (Logitech PRO X Gaming Headset),0x00200000,1,0,quartz.dll,10.00.18362.0900
Preferred DirectShow Filters
[HKEY_LOCAL_MACHINE\Software\Microsoft\DirectShow\Preferred]
<media subtype GUID>, [<filter friendly name>, ]<filter CLSID>
MEDIASUBTYPE_DVD_LPCM_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_AUDIO, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG2_VIDEO, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
{78766964-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_mp4s, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{64697678-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{58564944-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
{5634504D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_MP4S, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
{44495658-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMVA, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mpg4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_h264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_H264, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_WMV3, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_MP43, Mpeg43 Decoder DMO, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WMV2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS2, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_M4S2, Mpeg4s Decoder DMO, CLSID_CMpeg4sDecMediaObject
MEDIASUBTYPE_WVP2, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder DMO, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_WMV1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_MSS1, WMV Screen decoder DMO, CLSID_CMSSCDecMediaObject
MEDIASUBTYPE_WVC1, WMVideo Decoder DMO, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_AVC1, Microsoft DTV-DVD Video Decoder, CLSID_CMPEG2VidDecoderDS
MEDIASUBTYPE_MPEG_LOAS, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_MPEG_ADTS_AAC, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
MEDIASUBTYPE_WMAUDIO_LOSSLESS, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_WMAUDIO3, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
WMMEDIASUBTYPE_WMAudioV8, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder DMO, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft DTV-DVD Audio Decoder, CLSID_CMPEG2AudDecoderDS
WMMEDIASUBTYPE_MP3, MP3 Decoder DMO, CLSID_CMP3DecMediaObject
MEDIASUBTYPE_MPEG1Payload, MPEG Video Decoder, CLSID_CMpegVideoCodec
MEDIASUBTYPE_MPEG1Packet, MPEG Video Decoder, CLSID_CMpegVideoCodec
{6C737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64737664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
{64687664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_MJPG, MJPEG Decompressor, CLSID_MjpegDec
{20637664-0000-0010-8000-00AA00389B71}, DV Video Decoder, CLSID_DVVideoCodec
MEDIASUBTYPE_MPEG1AudioPayload, MPEG Audio Decoder, CLSID_CMpegAudioCodec
WMMEDIASUBTYPE_WMSP2, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
WMMEDIASUBTYPE_WMSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
Media Foundation File Versions
mfcore.dll, 10.00.18362.1198
mfreadwrite.dll, 10.00.18362.0719
mfcaptureengine.dll, 10.00.18362.0001
mfsensorgroup.dll, 10.00.18362.1171
windows.media.dll, 10.00.18362.0959
frameserver.dll, 10.00.18362.1171
fsclient.dll, 10.00.18362.1171
Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms]
<category>:
<transform friendly name>, <transform CLSID>, <flags>, [<merit>, ]<file name>, <file version>
Video Decoders:
NVIDIA MJPEG Video Decoder MFT, {70F36578-2741-454F-B494-E8563DDD1CB4}, 0x4, 8, nvDecMFTMjpegx.dll, 27.21.0014.5730
Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}, 0x1, msmpeg2vdec.dll, 10.00.18362.1198
DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}, 0x1, mfdvdec.dll, 10.00.18362.0001
Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT, 0x1, mp4sdecd.dll, 10.00.18362.1016
Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT, 0x1, msmpeg2vdec.dll, 10.00.18362.1198
WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject, 0x1, wmvsdecd.dll, 10.00.18362.0001
WMVideo Decoder MFT, CLSID_CWMVDecMediaObject, 0x1, wmvdecod.dll, 10.00.18362.1139
MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}, 0x1, mfmjpegdec.dll, 10.00.18362.0900
Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject, 0x1, mp43decd.dll, 10.00.18362.0001
Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject, 0x1, mpg4decd.dll, 10.00.18362.0001
VP9VideoExtensionDecoder
HEIFImageExtension
WebpImageExtension
Video Encoders:
NVIDIA H.264 Encoder MFT, {60F44560-5A20-4857-BFEF-D29773CB8040}, 0x4, 8, nvEncMFTH264x.dll, 27.21.0014.5730
NVIDIA HEVC Encoder MFT, {966F107C-8EA2-425D-B822-E4A71BEF01D7}, 0x4, 8, nvEncMFThevcx.dll, 27.21.0014.5730
H264 Encoder MFT, {6CA50344-051A-4DED-9779-A43305165E35}, 0x1, mfh264enc.dll, 10.00.18362.1049
WMVideo8 Encoder MFT, CLSID_CWMVXEncMediaObject, 0x1, wmvxencd.dll, 10.00.18362.0001
H263 Encoder MFT, {BC47FCFE-98A0-4F27-BB07-698AF24F2B38}, 0x1, mfh263enc.dll, 10.00.18362.0001
WMVideo9 Encoder MFT, CLSID_CWMV9EncMediaObject, 0x1, wmvencod.dll, 10.00.18362.0001
Microsoft MPEG-2 Video Encoder MFT, {E6335F02-80B7-4DC4-ADFA-DFE7210D20D5}, 0x2, msmpeg2enc.dll, 10.00.18362.0001
VP9VideoExtensionEncoder
HEIFImageExtension
Video Effects:
Frame Rate Converter, CLSID_CFrameRateConvertDmo, 0x1, mfvdsp.dll, 10.00.18362.0001
Resizer MFT, CLSID_CResizerDMO, 0x1, vidreszr.dll, 10.00.18362.0001
VideoStabilization MFT, {51571744-7FE4-4FF2-A498-2DC34FF74F1B}, 0x1, MSVideoDSP.dll, 10.00.18362.0001
Color Control, CLSID_CColorControlDmo, 0x1, mfvdsp.dll, 10.00.18362.0001
Color Converter MFT, CLSID_CColorConvertDMO, 0x1, colorcnv.dll, 10.00.18362.0001
Video Processor:
Microsoft Video Processor MFT, {88753B26-5B24-49BD-B2E7-0C445C78C982}, 0x1, msvproc.dll, 10.00.18362.0387
Audio Decoders:
Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}, 0x1, DolbyDecMFT.dll, 10.00.18362.1171
MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}, 0x1, MSAMRNBDecoder.dll, 10.00.18362.0001
WMAudio Decoder MFT, CLSID_CWMADecMediaObject, 0x1, WMADMOD.DLL, 10.00.18362.1082
Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT, 0x1, MSAudDecMFT.dll, 10.00.18362.1049
A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}, 0x1, mfcore.dll, 10.00.18362.1198
GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}, 0x1, mfcore.dll, 10.00.18362.1198
WMAPro over S/PDIF MFT, CLSID_CWMAudioSpdTxDMO, 0x1, WMADMOD.DLL, 10.00.18362.1082
Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}, 0x1, MSOpusDecoder.dll, 10.00.18362.0001
Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}, 0x1, MSFlacDecoder.dll, 10.00.18362.0778
Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}, 0x1, MSAudDecMFT.dll, 10.00.18362.1049
WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject, 0x1, WMSPDMOD.DLL, 10.00.18362.0001
G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}, 0x1, mfcore.dll, 10.00.18362.1198
IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}, 0x1, mfcore.dll, 10.00.18362.1198
MP3 Decoder MFT, CLSID_CMP3DecMediaObject, 0x1, mp3dmod.dll, 10.00.18362.0001
Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}, 0x1, MSAlacDecoder.dll, 10.00.18362.0001
ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}, 0x1, mfcore.dll, 10.00.18362.1198
Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}, 0x1, mfaudiocnv.dll, 10.00.18362.0001
DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}, 0x1, mfaudiocnv.dll, 10.00.18362.0001
Audio Encoders:
LPCM DVD-Audio MFT, {068A8476-9229-4CC0-9D49-2FC699DCD30A}, 0x1, mfaudiocnv.dll, 10.00.18362.0001
MP3 Encoder ACM Wrapper MFT, {11103421-354C-4CCA-A7A3-1AFF9A5B6701}, 0x1, mfcore.dll, 10.00.18362.1198
Microsoft FLAC Audio Encoder MFT, {128509E9-C44E-45DC-95E9-C255B8F466A6}, 0x1, MSFlacEncoder.dll, 10.00.18362.0719
WM Speech Encoder DMO, CLSID_CWMSPEncMediaObject2, 0x1, WMSPDMOE.DLL, 10.00.18362.1082
MS AMRNB Encoder MFT, {2FAE8AFE-04A3-423A-A814-85DB454712B0}, 0x1, MSAMRNBEncoder.dll, 10.00.18362.0001
Microsoft MPEG-2 Audio Encoder MFT, {46A4DD5C-73F8-4304-94DF-308F760974F4}, 0x1, msmpeg2enc.dll, 10.00.18362.0001
WMAudio Encoder MFT, CLSID_CWMAEncMediaObject, 0x1, WMADMOE.DLL, 10.00.18362.1082
Microsoft AAC Audio Encoder MFT, {93AF0C51-2275-45D2-A35B-F2BA21CAED00}, 0x1, mfAACEnc.dll, 10.00.18362.0001
Microsoft ALAC Audio Encoder MFT, {9AB6A28C-748E-4B6A-BFFF-CC443B8E8FB4}, 0x1, MSAlacEncoder.dll, 10.00.18362.0001
Microsoft Dolby Digital Encoder MFT, {AC3315C9-F481-45D7-826C-0B406C1F64B8}, 0x1, msac3enc.dll, 10.00.18362.0001
Audio Effects:
AEC, CLSID_CWMAudioAEC, 0x1, mfwmaaec.dll, 10.00.18362.0001
Resampler MFT, CLSID_CResamplerMediaObject, 0x1, resampledmo.dll, 10.00.18362.0001
Multiplexers:
Microsoft MPEG2 Multiplexer MFT, {AB300F71-01AB-46D2-AB6C-64906CB03258}, 0x2, mfmpeg2srcsnk.dll, 10.00.18362.1171
Others:
Microsoft H264 Video Remux (MPEG2TSToMP4) MFT, {05A47EBB-8BF0-4CBF-AD2F-3B71D75866F5}, 0x1, msmpeg2vdec.dll, 10.00.18362.1198
Media Foundation Enabled Hardware Categories
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\HardwareMFT]
EnableDecoders = 1
EnableEncoders = 1
Media Foundation Byte Stream Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\ByteStreamHandlers]
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\Preferred]
<file ext. or MIME type>, <handler CLSID>, <brief description>[, Preferred]
.3g2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.ac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.adt, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
.am?, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler
.amr, {EFE6208A-0A2C-49FA-8A01-3768B559B6DA}, MF AMRNB Media Source ByteStreamHandler, Preferred
.asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
.dvr-ms, {A8721937-E2FB-4D7A-A9EE-4EB08C890B6E}, MF SBE Source ByteStreamHandler
.dvr-ms, {65964407-A5D8-4060-85B0-1CCD63F768E2}, dvr-ms Byte Stream Handler, Preferred
.ec3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
.flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
.m2t, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m2ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mk3d, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mka, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mks, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mkv, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
.mod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mov, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp2v, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mp4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
.mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mpg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.mts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.nsc, {B084785C-DDE0-4D30-8CA8-05A373E185BE}, NSC Byte Stream Handler, Preferred
.sami, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.smi, {7A56C4CB-D678-4188-85A8-BA2EF68FA10D}, SAMI Byte Stream Handler, Preferred
.tod, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.ts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.uvu, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
.vob, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
.wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
.weba, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
.webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
.wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
.wtv, {65964407-A5D8-4060-85B0-1CCD63F768E2}, WTV Byte Stream Handler, Preferred
audio/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/aacp, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/eac3, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
audio/L16, {3FFB3B8C-EB99-472B-8902-E1C1B05F07CF}, LPCM Byte Stream Handler, Preferred
audio/mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/MP4A-LATM, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/mpa, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/mpeg3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/vnd.dlna.adts, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/vnd.dolby.dd-raw, {46031BA1-083F-47D9-8369-23C92BDAB2FF}, AC-3 Byte Stream Handler, Preferred
audio/wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
audio/webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
audio/x-aac, {926F41F7-003E-4382-9E84-9E953BE10562}, ADTS Byte Stream Handler, Preferred
audio/x-flac, {0E41CFB8-0506-40F4-A516-77CC23642D91}, MF FLAC Media Source ByteStreamHandler, Preferred
audio/x-m4a, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
audio/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
audio/x-mp3, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-mpeg, {A82E50BA-8E92-41EB-9DF2-433F50EC2993}, MP3 Byte Stream Handler, Preferred
audio/x-ms-wma, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
audio/x-wav, {42C9B9F5-16FC-47EF-AF22-DA05F7C842E3}, WAV Byte Stream Handler, Preferred
video/3gpp, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/3gpp2, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/avi, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/mpeg, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
video/vnd.dece.mp4, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/vnd.dlna.mpeg-tts, {40871C59-AB40-471F-8DC3-1F259D862479}, MPEG2 Byte Stream Handler, Preferred
video/webm, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, WEBM Byte Stream Handler, Preferred
video/x-m4v, {271C3902-6095-4C45-A22F-20091816EE9E}, MPEG4 Byte Stream Handler, Preferred
video/x-matroska, {1F9A2C18-D89E-463E-B4F4-BB90152ACC64}, MKV Byte Stream Handler, Preferred
video/x-ms-asf, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wm, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-ms-wmv, {41457294-644C-4298-A28A-BD69F2C0CF3B}, ASF Byte Stream Handler, Preferred
video/x-msvideo, {7AFA253E-F823-42F6-A5D9-714BDE467412}, AVI Byte Stream Handler, Preferred
Media Foundation Scheme Handlers
[HKEY_LOCAL_MACHINE\Software\Microsoft\Windows Media Foundation\SchemeHandlers]
<URL type>, <handler CLSID>, <brief description>[, Preferred]
file:, {477EC299-1421-4BDD-971F-7CCB933F21AD}, File Scheme Handler, Preferred
http:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler
http:, {9EC4B4F9-3029-45AD-947B-344DE2A249E2}, Urlmon Scheme Handler
http:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpd:, {44CB442B-9DA9-49DF-B3FD-023777B16E50}, Http Scheme Handler, Preferred
https:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpsd:, {37A61C8B-7F8E-4D08-B12B-248D73E9AB4F}, Secure Http Scheme Handler, Preferred
httpt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
httpu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcast:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
mcrecv:, {FA6D33D4-9405-4BA5-9983-12604AC8E77A}, Miracast Sink Scheme Handler, Preferred
mms:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
ms-appdata:, {CFC81939-3886-4ACF-9692-DA58037AE716}, MsAppData Scheme Handler, Preferred
ms-appx-web:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppxWeb Scheme Handler, Preferred
ms-appx:, {8DB0224B-3D65-4F6F-8E12-BEB4B78B8974}, MsAppx Scheme Handler, Preferred
ms-winsoundevent:, {F79A6BF9-7415-4CF3-AE10-4559509ABC3C}, Sound Event Scheme Handler, Preferred
rtsp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtsps:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspt:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
rtspu:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
sdp:, {E9F4EBAB-D97B-463E-A2B1-C54EE3F9414D}, Net Scheme Handler, Preferred
Preferred Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\Preferred]
<media subtype GUID>, [<transform friendly name>, ]<transform CLSID>
{EB27CEC4-163E-4CA3-8B74-8E25F91B517E}, Dolby TrueHD IEC-61937 converter MFT, {CF5EEEDF-0E92-4B3B-A161-BD0FFE545E4B}
{E06D802C-DB46-11CF-B4D1-00805F6CBBEA}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFVideoFormat_MPEG2, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MEDIASUBTYPE_DOLBY_DDPLUS, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
{A61AC364-AD0E-4744-89FF-213CE0DF8804}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{A2E58EB7-0FA9-48BB-A40C-FA0E156D0645}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{7634706D-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{73616D72-767A-494D-B478-F29D25DC9037}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
MEDIASUBTYPE_mp4s, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_DVSL, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVSD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
MFVideoFormat_DVHD, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{63616C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
MFVideoFormat_MP4V, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_MP4S, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
{53314356-0000-0010-8000-00AA00389B71}, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVR, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_WMVP, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MJPG, MJPEG Decoder MFT, {CB17E772-E1CC-4633-8450-5617AF577905}
MEDIASUBTYPE_WMVA, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{3F40F4F0-5622-4FF8-B6D8-A17A584BEE5E}, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MEDIASUBTYPE_mpg4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MPG4, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_H264, Microsoft H264 Video Decoder MFT, CLSID_CMSH264DecoderMFT
MFVideoFormat_WMV3, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
{33363248-0000-0010-8000-00AA00389B71}, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_mp43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MFVideoFormat_MP43, Mpeg43 Decoder MFT, CLSID_CMpeg43DecMediaObject
MEDIASUBTYPE_m4s2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MFVideoFormat_WMV2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS2, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_M4S2, Mpeg4s Decoder MFT, CLSID_CMpeg4sDecMFT
MEDIASUBTYPE_WVP2, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MEDIASUBTYPE_mp42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MEDIASUBTYPE_MP42, Mpeg4 Decoder MFT, CLSID_CMpeg4DecMediaObject
MFVideoFormat_WMV1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_MSS1, WMV Screen decoder MFT, CLSID_CMSSCDecMediaObject
MFVideoFormat_MPG1, Microsoft MPEG Video Decoder MFT, {2D709E52-123F-49B5-9CBC-9AF5CDE28FB9}
MFVideoFormat_WVC1, WMVideo Decoder MFT, CLSID_CWMVDecMediaObject
MFVideoFormat_DVC, DV Decoder MFT, {404A6DE5-D4D6-4260-9BC7-5A6CBD882432}
{0000F1AC-0000-0010-8000-00AA00389B71}, Microsoft FLAC Audio Decoder MFT, {6B0B3E6B-A2C5-4514-8055-AFE8A95242D9}
{00007361-0000-0010-8000-00AA00389B71}, MS AMRNB Decoder MFT, {265011AE-5481-4F77-A295-ABB6FFE8D63E}
{0000704F-0000-0010-8000-00AA00389B71}, Microsoft Opus Audio Decoder MFT, {63E17C10-2D43-4C42-8FE3-8D8B63E46A6A}
{00006C61-0000-0010-8000-00AA00389B71}, Microsoft ALAC Audio Decoder MFT, {C0CD7D12-31FC-4BBC-B363-7322EE3E1879}
{00002001-0000-0010-8000-00AA00389B71}, DTS IEC-61937 converter MFT, {D035E24C-C877-42D7-A795-2A8A339B472F}
{00002000-0000-0010-8000-00AA00389B71}, Microsoft Dolby Digital Plus Decoder MFT, {177C0AFE-900B-48D4-9E4C-57ADD250B3D4}
MFAudioFormat_AAC, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_ADTS, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_WMAudio_Lossless, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV9, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MFAudioFormat_WMAudioV8, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_MSAUDIO1, WMAudio Decoder MFT, CLSID_CWMADecMediaObject
MEDIASUBTYPE_RAW_AAC1, Microsoft AAC Audio Decoder MFT, CLSID_CMSAACDecMFT
MFAudioFormat_MP3, MP3 Decoder MFT, CLSID_CMP3DecMediaObject
MFAudioFormat_MPEG, Microsoft MPEG Audio Decoder MFT, {70707B39-B2CA-4015-ABEA-F8447D22D88B}
{00000031-0000-0010-8000-00AA00389B71}, GSM ACM Wrapper MFT, {4A76B469-7B66-4DD4-BA2D-DDF244C766DC}
{00000011-0000-0010-8000-00AA00389B71}, IMA ADPCM ACM Wrapper MFT, {A16E1BFF-A80D-48AD-AECD-A35C005685FE}
KSDATAFORMAT_SUBTYPE_MULAW, G711 Wrapper MFT, {92B66080-5E2D-449E-90C4-C41F268E5514}
{00000006-0000-0010-8000-00AA00389B71}, A-law Wrapper MFT, {36CB6E0C-78C1-42B2-9943-846262F31786}
KSDATAFORMAT_SUBTYPE_ADPCM, ADPCM ACM Wrapper MFT, {CA34FE0A-5722-43AD-AF23-05F7650257DD}
MFAudioFormat_MSP1, WMSpeech Decoder DMO, CLSID_CWMSPDecMediaObject
Disabled Media Foundation Transforms
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\Transforms\DoNotUse]
<transform CLSID>
Disabled Media Sources
[HKEY_LOCAL_MACHINE\Software\Classes\MediaFoundation\MediaSources\DoNotUse]
<media source CLSID>
EVR Power Information
Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
Quality Flags: 2576
Enabled:
Force throttling
Allow half deinterlace
Allow scaling
Decode Power Usage: 100
Balanced Flags: 1424
Enabled:
Force throttling
Allow batching
Force half deinterlace
Force scaling
Decode Power Usage: 50
PowerFlags: 1424
Enabled:
Force throttling
Allow batching
Force scaling
Decode Power Usage: 0
Diagnostics
Windows Error Reporting:
+++ WER0 +++:
Fault bucket 1895295507173714296, type 5
Event Name: BEX64
Response: Not available
Cab Id: 0
Problem signature:
P1: NVDisplay.Container.exe
P2: 1.28.2851.9944
P3: 5edfa063
P4: NVDisplay.Container.exe
P5: 1.28.2851.9944
P6: 5edfa063
P7: 000000000005d975
P8: c0000409
P9: 0000000000000007
P10:
+++ WER1 +++:
Fault bucket 1324728874157915868, type 5
Event Name: RADAR_PRE_LEAK_64
Cab Id: 0
Problem signature:
P1: DeadByDaylight-Win64-Shipping.exe
P2: 4.25.1.0
P3: 10.0.18363.2.0.0
P4:
P5:
P6:
P7:
P8:
P9:
P10:
+++ WER2 +++:
Fault bucket 1471358335662480465, type 1
Event Name: APPCRASH
Cab Id: 0
Problem signature:
P1: vulkandriverquery.exe
P2: 0.0.0.0
P3: 5f9a002b
P4: MirillisActionVulkanLayer.dll
P5: 0.0.0.0
P6: 5e7e4ade
P7: c0000005
P8: 00012294
P9:
P10:
+++ WER3 +++:
Fault bucket 1599161585758368258, type 4
Cab Id: 0
Problem signature:
P1: vulkandriverquery64.exe
P2: 0.0.0.0
P3: 5f9a001c
P5: 0.0.0.0
P6: 5e7e4acd
P7: c0000005
P8: 0000000000011665
P9:
P10:
+++ WER4 +++:
Fault bucket 1991962815027637989, type 5
Event Name: ScriptedDiagFailure
Cab Id: 0
Problem signature:
P1: Microsoft Corporation.AudioPlaybackDiagnostic.4.5
P2: RC_HDAudioDriver/USB\VID_046D&PID_0AAA&MI_00\A&26545131&0&0000
P3: 1.0.0.0
P4: Default
P5:
P6:
P7:
P8:
P9:
P10:
+++ WER5 +++:
Fault bucket , type 0
Cab Id: 0
Problem signature:
P3: 1.0.0.0
P4: Default
P5:
P6:
P7:
P8:
P9:
P10:
+++ WER6 +++:
Fault bucket 1845544392355173401, type 5
Cab Id: 0
Problem signature:
P1: NVIDIA Broadcast.exe
P2: 219.0.0.0
P4:
P5:
P6:
P7:
P8:
P9:
P10:
+++ WER7 +++:
Cab Id: 0
Problem signature:
P2: 0.0.0.0
P3: 5f9a002b
P5: 0.0.0.0
P6: 5e7e4ade
P7: c0000005
P8: 00012294
P9:
P10:
+++ WER8 +++:
Cab Id: 0
Problem signature:
P2: 0.0.0.0
P3: 5f9a001c
P5: 0.0.0.0
P6: 5e7e4acd
P7: c0000005
P9:
P10:
+++ WER9 +++:
Fault bucket 2261462044125663856, type 1
Cab Id: 0
Problem signature:
P1: AORUS.exe
P2: 1.9.2.0
P3: 5fa3b862
P4: ntdll.dll
P5: 10.0.18362.1171
P6: e94aeef6
P7: c015000f
P8: 000983fc
P9:
P10:
Tue Nov 17, 2020 6:59 am
It is a different problem. Uninstall NVidia broadcast. That should help.
