NLByron
PC Specification: I9, GeForce RTX 20, W10
Best FPS resolution for desktop capture?
Fri Nov 13, 2020 8:49 am
I have a problem (who doesn't, right?)
In the following configuration:
Resolution 1920 x 1080 (Fullscreen monitor)
720p resolution video capture
Video 20' = 3 GB! :oops: :oops: :oops: :oops:
Please, how many FPS should I place in Mirillis Action!
David Nathaniel Katzenbach
Re: Best FPS resolution for desktop capture?
Tue Nov 17, 2020 7:02 am
You can record in 60 fps.
logosmall87
PC Specification: Core i5, 12 gb ram, AMD Radeon 530, HDD
Fri Jun 25, 2021 12:00 pm
Try using the resolution 4 to 3 and recoed in 120 fps, that could help.
Saunders
PC Specification: i5 4440, R9 290, 16GB ram Windows 10
Mon Oct 18, 2021 12:58 pm
Maybe try to compress it later in video editing software...
AlexPhilip
PC Specification: Windows 10
Fri Oct 22, 2021 12:49 pm
The aspect ratio does not matter at all in terms of FPS numbers. People playing in 4:3 ratios also tend to crank the resolution much lower as well, so maybe that's where the idea that it has better performance comes from.
Multiply a resolution's vertical pixels by its horizontal pixels. The larger the product, the larger the FPS hit will be. The final number (area) is all that matters for effect on performance.
gamer
Return to “General Topics”
