NLByron
PC Specification: I9, GeForce RTX 20, W10
Mirillis Action! issue
Fri Nov 27, 2020 9:09 pm
Hi!
I got a glitch in capturing one area of a video playing on fullscreen. Mirillis Action! allows you to resize the width but not the height of the captured area. The maximum height in pixels is 996, and even though I introduce the height I wish to capture, the height cannot be higher than the pixels specified.
Can this issue be fixed, or Mirillis Action! doesn't support capture of an area in a video with a height higher than 996 pixels?
Thank you.
David Nathaniel Katzenbach
PS: I uploaded a capture you can see my issue.
https://imgur.com/gallery/bIbXvwj
Re: Mirillis Action! issue
Mon Nov 30, 2020 8:31 am
Hello.
Recording area need to fit on your screen. You can resize the area by pressing left shift key and arrow keys.
