erro
PC Specification: I9-9900 32GB-RAM 2070Super
Action is stuck on the splashscreen for a long time - loading modules
Sat Nov 28, 2020 7:57 am
Hello, as the title says, I can't start Action very fast. every time I start it, it stays in the loading module for maybe more than 20 minutes. I can see the FPS counter at the top right, but I can't click on anything. The splash screen is always at the top, covering all the actions that follow. I can stop it via Steam, but it also takes several minutes to stop. Otherwise I have to restart the computer to get rid of it.
I've seen a similar post here. I tried uninstalling it, downloading the last version, and reinstalling it. Same result.
This is a screenshot of the startup screen. https://ibb.co/hmv2DFp
This is the DxDiag ,I've seen that you request that.
https://drive.google.com/file/d/1Y4Uhuv ... sp=sharing
Re: Action is stuck on the splashscreen for a long time - loading modules
Mon Nov 30, 2020 8:32 am
Please uninstall NVidia Broadcast and see if that helps.
erro
Thu Dec 03, 2020 11:50 am
OK, I uninstalled RTX and it loaded OK. So is this an Action compatibility issue or an RTX issue?
junit1783
PC Specification: Ryzen 7 GTX titan windows 11
Sun Jan 01, 2023 10:46 pm
I dont have broadcast installed and no luck still stuck on splash screen
Wed Jan 04, 2023 6:54 am
Press Windows key + R to open "Run" window.
Type msinfo32 and click OK to open System Information.
Now click File -> Save. Save the file on your desktop, this can take a while.
Attach generated file to your reply.
