crl2007
Playlist Rename Change
Sat Jan 01, 2011 10:27 am
Now, when you rename an item in the playlist, it renames the file too. It would be great if it would be possibly to rename only the playlist entry rather than the whole movie.
Re: Playlist Rename Change
Sun Apr 10, 2011 10:15 pm
Thanks for this suggestion I will keep it to consider for future versions.
Both solutions have its good and bad sides and it would require probably an option somewhere in settings.
