philstopford
PC Specification: 9700K, 1080, 10H2
Record window of application at original size
Mon Feb 08, 2021 3:30 pm
When I try recording a windowed application, it seems that the output video is sized to the full screen resolution, rather than the window size. I can't see how to control this behavior and wanted to ask whether this was expected and/or configurable.
Re: Record window of application at original size
Tue Feb 09, 2021 6:59 am
Hello.
Yes, that is normal.
philstopford
Sun Feb 14, 2021 7:02 pm
OK. Is that something that could be changed, so that the recording is made at the window size, or is this a fundamental part of how your tool works?
philstopford
Thu Mar 18, 2021 5:13 pm
Just wanted to follow-up on this; is it possible for you to enhance the tool in order to record at the window size (not screen size)?
