Rapid99
PC Specification: i7-6700k, EVGA GTX980 Ti, 32GB DDR4 2666
Can no longer change Output Folder
Sun Feb 14, 2021 12:00 am
I've been using Action! for years and for some reason this problem only just started happening recently.
Any time I try to change the Output folder for where my recorded videos save, the mouse cursor will pinwheel and stay like that forever; it will never open Windows Explorer so I can select a new folder, and I have to force close Action! after a while.
I have tried re-installing Action!, and I cleared the registry as well to reset all settings to default, but that didn't work unfortunately...
Re: Can no longer change Output Folder
Tue Feb 16, 2021 7:01 am
Open command prompt as an administrator and type in: sfc /scannow
Wait for scan to complete and restart your PC.
Rapid99
Fri Feb 19, 2021 12:39 am
I ran SFC and some damaged files were found and repaired by Windows; unfortunately, following a restart, the problem with Action! still persists :/
Users browsing this forum: No registered users and 47 guests
