DEViANCE
PC Specification: win 10
Cannot Drag
Tue Apr 06, 2021 8:51 am
I have dual screen setup and usually I drag the mirillis action screen to my second monitor, but for some reason it won't let me, every other program i can drag across, but Mirillis won't, can't for the life of me figure out why.
Thanks in advance.
Re: Cannot Drag
Wed Apr 07, 2021 6:14 am
1. Uninstall Action!
4. Remove Action! catalog.
5. Reboot your PC.
Users browsing this forum: No registered users and 47 guests
