Pepsyi
PC Specification: Windows 8.1
CS:GO ~200fps less when ACTION! is running
Wed Apr 07, 2021 8:47 pm
Hey everyone,
I hope someone can help me.
I got the problem that my CS:GO is loosing a lot of FPS as soon as Action is opened.
Standard Frames: 300fps
Opening Action: 80-140fps
I tried the following things:
Reinstall Action (with regedit) = 80-140fps
Changing the Settings in Action (MP4, AVI, NVENC) = 80-140fps
Time-Shift on/off = 80-140fps
Hiding the HUD = 80-140fps
Changing CS:GO Settings (Graphics, Resolution) = 80-140fps
Changing the recording mode to "Device" = 300fps
Closing Action = 300fps
Action and my drivers are Up-To-Date
PC Specs:
Intel i5 8600K - 6 x 3.60GHz
GeForce GTX 1070 Ti
I hope someone has an idea what I can do to fix the problem. OBS does work fine
Thanks guys!
Cheers Pepsyi
Re: CS:GO ~200fps less when ACTION! is running
Thu Apr 08, 2021 5:54 am
Hello.
There is no reason for this fps drop to happen. It works fine on our end. Do you run CS:GO with some launch options?
Pepsyi
[SOLVED] Re: CS:GO ~200fps less when ACTION! is running
Thu Apr 08, 2021 3:35 pm
Hey Piotr,
I managed to fix it!
Live -> Overlay-Source
I used a custom overlay in "HUD + Record" set to 60 FPS
That caused the FPS drops. Disabling it helped a lot.
Thanks guys for such a good software! :)
Cheers Pepsyi
- No idea if I can set this post as "Solved".. i changed the Subject :D
Return to “General Topics”
