Drahy
PC Specification: Windows 10, RTX 2070 Super
Action window missing some things
Thu Apr 22, 2021 2:03 pm
In recent version I cannot resize or move my Mirilis Action window on my Windows 10 desktop - did I setup anything wrong that i lost this option? No maximize window icon or not possible to move the window by mouse ... only minimize, close and dot option.
Thank you.
Re: Action window missing some things
Fri Apr 23, 2021 5:36 am
1. Uninstall Action!
4. Remove Action! catalog.
5. Reboot your PC.
