Jakov93
PC Specification: Intel i7
Move to certain time on progress bar
Fri Apr 30, 2021 11:10 am
Hi All
Please why I can't move to a certain time on the progress bar of Mirillis Splash player
for example if I want to move to 1:20
when I click on that time on the progress bar, It moves to 1:25 or some time 1:12.
So what causes this problem? also most multimedia player have the same problem in moving or jumping to a certain time on progress bar.
Thanks
plausiblefell
PC Specification: CPU
Re: Move to certain time on progress bar
Fri Dec 27, 2024 7:10 am
The issue occurs due to keyframe intervals in the video file. Players can only seek to the nearest keyframe. Re-encode the video with shorter keyframe intervals or use a precise player like VLC.
SprunkiRetake
PC Specification: Windows 11
Fri Oct 10, 2025 6:30 am
please give specific steps to do that encryption! i am new and sorry if my request is silly! :P
sabirose
Thu Feb 05, 2026 9:02 am
where trying to make a precise move can sometimes be trickier than expected. It might be a buffering or syncing issue with the player, or possibly the way it's handling time jumps. Hopefully, there’s a setting or update that can smooth it out!
Sterlingg
PC Specification: Dell 3104
Fri Mar 20, 2026 7:44 am
Could the problem with the progress bar jumping to incorrect times be related to the video file's encoding or the way the player handles seeking?
strictgaze
PC Specification: Windows 11 Pro 64-bit (23H2)
Mon Mar 30, 2026 3:35 am
This usually happens because of keyframe-based seeking—most players jump to the nearest keyframe instead of the exact timestamp. The spacing between keyframes depends on how the video was encoded, so it can feel imprecise. It’s normal behavior in many media players, not just Splash.
minakylier
PC Specification: Intel Core i5-12400
Thu Jun 04, 2026 3:14 am
Sometimes it might occasionally be more difficult than anticipated to execute a precise maneuver. It might be a problem with the player's buffering or synchronization, or it could be the way it handles time jumps. Hopefully, an update or setting can make things easier!
henrykang
Fri Jun 05, 2026 2:24 am
when attempting a precise manoeuvre can occasionally out to be more challenging than anticipated. It could be due to the player's buffering or syncing issues, or it could be related to how it handles time jumps. It would be great if there was an update or setting that could fix it!
Return to “Splash 2.0”
